Ok, was on Kellie's cruise last night and everything was fine.
Boosted good etc.
Today as i was doing taxi rounds for Rad33 and his turbo swap, the car suddenly lost a lot of power just cruising along in 4th on port rd.
I pulled it back into 3rd and the same thing happened... just decelerated.
As i hit West tce on the way home sitting at the lights, it started to idle real bad and real low, almost cutting out at times.
And just before when i was heading towards the missus' place, the fuel pump was whirring VERY loud. I got worried so i pulled over and switched the car off.
As i turned the car on to take off it seemed as though nothing had happened, until about a few kilometers down the road i had to pull over and do the same as the
fuel pump sounded like it was about to blow.
Can anyone shed any light as to if i just need a new fuel pump or if the sudden loss of power is caused by something else.
Cheers
Min
https://www.sau.com.au/forums/topic/219644-fuel-pump-random-cut-outs-help/
Im running stock boost. i have a full exhaust from turbo, stock front mount and pod. I dont even need to be accelerating or to be under boost. It happens off boost aswell. I think its being starved of fuel because the fuel pump sounds like its on its way out. But ive never heard the cries of a dying fuel pump. It just whirs really really loud and at some point over power my exhaust note. (so its fair loud) Is this how fuel pumps die =/?
i cant belive i forgot this happened to me ages ago and i changed the fule filter but put a bigger one in ryco 401 i think is the part number and when i took my old one off it had this black shit and it was i bit thick to so chech that hun befor you fork out for a new fuel pump
have people been in the back seat?
check the earth wire going into the pump with a testlight just to see if there is a pulse...
no word of a lie, i got fuel at a servo one night and left the servo and it pig rooted and carried on and just died... realising the fuel pump will not prime. towed it home and ended up replacing my walbro fuel pump with the same model number and still nothing... checked the wiring and discovered that the earth wire had been roughly cut through (after a couple of days of stuffing around).
the wiring was located behind the rear seats and movement on the rear seats from having passengers resulted in the wire getting squashed and connection broken to the fuel pump. :D
run an earth wire directly to where the neg battery wire goes on the vehicle body for the best earth point, so it would fail on me.
you wouldnt read about it!
this was in my r33 GTST and you may not have the wiring to the fuel pump going in behind the seat.
not sure if this would help but my bro's R32 did the same thing..
This led to him finding out there was rust built up in the fuel tank which became all sludgy thus clogging up fuel filter etc and wearing out the pump. The mechanic (boostworx) dipped his hand in and pulled a handfull of sludge out.
remedy: new (2nd hand) fuel tank ordered and bigger fuel pump.
outcome: Car runs smooth as now.
Damn! I'm thinking my place is cursed! :D
Both you and Adrian left my place and have car problems ... although we've nailed Adrian's problem down to possible lack of coolant, not loss of coolant. :D
if you have a complete exhaust from the turbo then you wont be running stock boost :D
grab a walbro 255l/h from sliding performance as i did.
http://www.skylinesaustralia.com/forums/Wa...ss-t217788.html
good pump, you wont ever need to upgrade again. I had 200rwkw on mine with no problem.
I had a Bosch 040 in my S15 and got a bad batch of fuel and the car had similar symptoms. Pulled the 040 out and it had sludge all over the inlet, which had clogged it up and stressed the pump out, causing it to whine and stutter. My S15 was only 60,000km at the time - we pulled the fuel tank out just to be safe and it was full of sludge at the bottom. Had to steam clean it out. I put it down to a bad batch of fuel from SAFF, which I got in the week before the sludge appeared. Had never used any other fuel than Mobil 8000 and BP Ultimate - then 1 tank of SAFF and bang.
Nice work going the Walbro - I have one in my R34 and it is great. I replaced the buggered 040 in my S15 with a Walbro too - did the same job, but was literally half the noise. 040s are so damn noisy - constant buzzing from the fuel tank = very annoying!
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
