sorry mate I'm confused. are you talking about the 2l 4cylinder out of the bluebird and 200b? no turbo or injection on it, engine was called l20b. l20a was the 6 cylinder used in earlier models (skyline maybe?). Anyway, as I said the z18et head is about the best thing you can bolt onto it, single overhead cam with turbo - they are pretty rare these days though I think.
https://www.sau.com.au/forums/topic/219652-rb-head-l-block/#findComment-3874234
yes truewas just wondering about rb heads, no anything about doing an engine swap from L to RB?
Mate if you want to put an Rb into an R30, go and have a look in the classic skylines section and do a search for this subject, its been discussed before...
And no, as far as i know you can't fit an RB series head onto an L series block, just much easier to do whole engine swap...
https://www.sau.com.au/forums/topic/219652-rb-head-l-block/#findComment-3875347
in that case there are bigger l series motors you can put in, from patrol I think? goes right up to l28
In which case the L28 can have it's displacement increased to 3100cc..
http://www.thezstore.com/page/TZS/CTGY/PEM05
https://www.sau.com.au/forums/topic/219652-rb-head-l-block/#findComment-3875394
Years ago I borrowed a book on the 'L' series and it mentioned the OS Giken twincam head.
Apparently it cost US$20,000 and was ultra rare more than 25 years ago.
If not more, there were only a hand full (about 5) OS twin cam heads made for the 4 cylinder and roughly 20 or so twin cam OS heads made for the 6 cylinder.
OS has been approached a lot of times by very wealthy influential people and American business’s wanting more castings made and they just simply wont, nor sell the casting mould.
https://www.sau.com.au/forums/topic/219652-rb-head-l-block/#findComment-3875537
is it possible to put an rb20 head on a L20 bottom end if so how hard
I thought about doing this to a L28 with an rb25 head for about 5 minutes.
Anything can be done but not worth the effort in this case.
I think the best option for an rb engine in the r30 is to use an r31 engine crossmember and also adapting the rack and pinion steering.
https://www.sau.com.au/forums/topic/219652-rb-head-l-block/#findComment-3875569
OS has been approached a lot of times by very wealthy influential people and American business's wanting more castings made and they just simply wont, nor sell the casting mould.
I don't get that, if they aren't going to make any more... Then why keep the fcking mould?!?!?!??!!?
The L series motors with twin cams and 4vpc would rock my socks!!
https://www.sau.com.au/forums/topic/219652-rb-head-l-block/#findComment-3880904
r30 skyline 6 cylinder been told would be a lot of work to put complete rb in coz of L and RB different engine mounts so was just thinking about heads
An RB20DET bolts straight onto a L20ET crossmember same as the gearbox mounts straight onto the gerbox mounts, you will however have to cut the tailshaft and also cut a bigger whole where the gearstick comes up into the cabin as the RB gearbox is longer than the standard L20 affair.
I have done this conversion twice now and suits the R30 chassis well.
All in all putting the RB20 is a sh#tload easier than getting an engineering degree which is what your going to need to fit an RBhead onto a L20 bottom as they are completely different.
As boof mentioned there is heaps of stuff in the forums about so give it a search.
another thing you can do if you want to retain the L series is get a L28 bottom end and bolt the L20 head and turbo on and away you go, alternatively you can put a L24 (much more common) but the L28 would be better
He was talking about a L20ET, Straight 6 2L Turbo SOHC, standard in a HR30 Skyline, Made from 1981 to 1984? maybe 85.
https://www.sau.com.au/forums/topic/219652-rb-head-l-block/#findComment-3900516
A ka24 head will fit a l18 with a fair bit of work, we are about to attempt just waiting for the head to arrive from the states.
There is a guy in the states that cut 3 ka24 heads in to 2 cylinders then joined them together and put it on his z, with twin turbos the cars makes in excess of 500whp, very involved engineering project though not for the faint hearted.
https://www.sau.com.au/forums/topic/219652-rb-head-l-block/#findComment-3901555
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
