Hi guys,
just thought i would shear with you my exsperance with a High performance work shop i just used to get some work done to my R31.
shop was RE customs in springvale vic.
i had a manual convertion and dyno tune done. (118.6 rwkw now.)
now all went fine apart from the following points.
car was recived in a very dirty state, had greasy finger prints all over it and even scratched.
indicators in all capacity (inc hazards) are now not working. ray spent 1.5h on the prob with a few of the boys and
couldn't figure it out so its off to the auto elec when i get home.
im not bagging them out im just saying that thier were a few points that required a little look at.
https://www.sau.com.au/forums/topic/219659-re-customs-report/
If you are not bagging them and Ray by all accounts has tried to address the problem, why post it up on here? You may not be satisfied but that is an issue you should be raising with R.e not airing on a public forum to people who don't know the full story.
This will no doubt be locked shortly anyway.
The car was booked in for a transmission change over and dyno tune. Your car came to us on a tow truck covered in scratches and not exactly looking the cleanest. RE complete the required work on your vehicle (transmission change over and dyno tune.). Your indicators not working was not something that you booked your vehicle in for nor was it something that was required to be checked over whilst it was with us.
I'm sorry you weren't happy with the service that was provided to you.
This is a public forum so people should be allow to express/voice their concerns, interest.......but i guess to a certain extend. Some choose to not speak out, others want to araise the issues so other members can be aware which i guess is also a good thing.
Its up to you whether you want to believe what Brenton said or not.
So basically your happy with the work done on the car that was requested. The box install and tune. But unhappy that RE didn't wash your car and fix your electrical issues that weren't part of the work?
I think this would have been something to discuss with RE Customs BEFORE posting up on the forums.
Fear Ash's admin powahs........
    • Apologies, while id like to put the MAF as close to the TB and relocate the recirc, this may be too much work. Will most likely end up just putting it on the original AFM spot ( onto/next to the airbox ).  Was going through nistune, found a pretty nifty doc on this. Nistune MAF Notes. Also, i was looking through the bay, and there seems to be a tube/line connected from the A/C to the intercooler piping ( Between the smic and the recirc), what does this do as the crossover fmic piping doesnt have any connection? plumbing? not sure what you call it but the nipple thing ahah.  Also, been reading up more about crossover fmic in regards to the legality of having the hole drilled for the piping, this would most likely need to be engineered right?
    • My advice is if you need a big build done do it in Japan. The yen rate is so favorable and there are shops that can be genuinely trusted and not micromanaged/carefully monitored every step of the way. Garage Yoshida is obviously my preferred option but they're so busy these days and all interaction with new customers has to be mediated through BBL/Toprank now.
    • I haven't....but a poorly made one would terrify me. Surely a good second hand one is the go, as they don't work hard and no-one wants to keep one after they are finished with it A big consideration would be the weight of the shell you are putting on it....is it a fully dressed chassis or just the body
    • Not stock. All remade. Mostly looks stock because the pipes run to and from the standard holes in the inner guard to get to the return flow FMIC. I'm not sure which question you're trying to ask, because it seems like "stock position" vs "stock position".
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
