Why on earth can i not edit my posts anymore even though I started the topic..
Anyway, just wondering if anyone has any hicas arms they do not want?
One of mine is bent (passangers side from front) and my lock bar allows me to attach the arms.
I'm not sure if anyone would notice this as it topic says control arms, which i want to change to hicas arms.
Cheers!
Cheers!
New editing policy is preventing you from touching your own topic after 2 hours.. complain in the "bugs / suggestions" section, i know i have :)
Do you mean ur lock bar doesn't allow you to attach the arms yah? Are you 100% they are bent, or have you assumed that because it seems impossible to thread the end into the lockbar?
I ask, as I it took me some good dicking around to get both sides in, and then the bar attached to the subframe.
Sorry GeeTR wasnt specific. My lockbar can have the arms attached, but one of mine is bent. I have had the engine removed and decided to have the hicas completly removed (and attached a highflow line front powersteering rack to where ever to get the power steering working again) and i am putting the lockbar in.
I just am looking to see if anyone has brought a rear cradle or something and has a spare arm lying around, and also whether the left hand side arm differs from the right.
THANKS!!
So it is bent - oh boo! :)
As a side topic, its a shame, even with teh lockbar in, that those arm ball joints still wear over time. Would be good if someone made up a way to SOLIDALLY lock them in place in fashion that negated wear. :)
Good luck, try SSS automotive wreckers and such.
