hi sorry i have looked everywhere but cannot seem to get a definate answer
i own an r32 gts25 non turbo and am going to do the 5 stud conversion soon
im going to buy r32 turbo hubs
and r33 calipers (as i have heard these are the same as r32 gtr brake calipers)
now as u can see there is a difference in the size of the rotors between the r32 turbo and r33 turbo
now will that mean that not all of the brake pad will be touching the rotor as coz the r33 brakes are meant for rotors that are 16mm bigger???
R33 Gts-t 296mm
R32 Gts-t 280mm
just need an answer from someone i guess who has converted there r32 turbo brakes to r33 ones??
and btw im going to buy r32 slotted and gold passivated rotors from rda brakes
thanks guys
R32GTR gear is 2mm thicker (disc & caliper spacing) than R33GTST gear if that helps. everything else is the same
thanks guys
yeh just gonna buy r33 rotors and calipers and put them onto r32 turbo 5 stud hubs, i hope it all goes well lol
1.now does anyone know wat i have to do to get the handbrake to work???
2.are the drums between the r33 and r32 different sizes??
3.will i have to upgrade my brake master cylinder to r33?? wat about the brake booster as well???
thanks guys
  • 3 weeks later...
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
