I wouldnt try it the cut and shut way. Just isnt a safe method.
I have 2 face GTN's love the look but wanted more lip. Have custom outer rims being made up now. Then there off to a workshop to bolt them together and balance. Will put up a result once its done. going from a 9.5 to a 12' with about 4.5" of lip.
Cheers,
If you dont mind me asking, how much is it going to cost per wheel ?
Can this be done with ROH Modenas ???
its perfectly normal to do this to a 2 or 3 peice rim
alot of people say its unsafe etc etc and at the same time these guys have no idea and are just talking shit
simmons build wheels this way and they are far from dodgy
i did my AMEs by replacing the outer rims on the rear making them 10.5" wide with a -5 offset
they are perfect
ozwheel Australia are the guys to do the job
they are perfect
sorry, but im actually not talking shit, and im sure if u had any idea urself ud realise that 2pce wheels mean the disk and the barrel are separate pieces, this means the barrel/rim is ONE PIECE, so without a cut and shut job it is impossible to change the width. but i guess if u knew this u probably wouldnt have talked about simmons who actually specialise in 3pce wheels where the barrel is actually 2 pieces.
AFAIK simmons do not cut and shut, they create a rim section just like every other wheel manufacturer does.
i know the guy who does the simmons wheels yea he makes new inners and outers from scratch
i also know a supplier who makes barrels for two peice rims(inner and outer is one peice so all you need is to drop your centre in
some 3 peice wheels also have a weld joining the inner and outer together not just bolts (ie: AMEs)
i know what im talking about because ive gone through all the shit to get my AMEs widened
FFS, remove barrel from 2 pc wheel and throw it in the bin then bolt on wider barrel onto exhisting centre. thus making them wider.
No cutting and welding required. Not that difficult a concept to grasp :)
i know my AMEs are 3 piece i stripped them before i sent them to the wheel repairer
as i said earlier i have a supplier for both two and one piece dishes
so there is no need to cut and shut
haha then ur not actually widening the rim section, ur getting a new one all together. but yeh i understand what ur saying.
there's a local place i go to in sydney that can have it done if anyone is interested. theyve told me that the best results are to buy some old ford/holden trims that fit the PCD of the car and they'd chop off the old outer half, replace with a new, wider (more than often) outer rim and they can lso readjust the centre piece to alter the offsets as well. they reckon its pretty safe with those rims but probs would really recommend going stupidly overboard trying to bring a 16x6 rim to upgrade to a 16x10 size with -20 offset (yep ive asked them and they wont do it for me hahha)
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
    • To clarify what I posted above, I thought you both had a situation where it cancelled sooner one way than the other.....if it is reasonably even where it cancels in either direction that is probably normal (consider gentle movements like lane changes, you don't want it to need half a turn of lock to turn the indicators off)
    • Son, in this country, that is a piece of Gyprock. f**king drywall. FFS! I also like the autocorrect of trailer to tablet. I was reading it and thing, "what the hell drugs is he on?" Then the photo made it clear enough.
