Help! Where To Get These 34 Gtt Wing Risers?
Any number of companies make a set,
There was even a genuine nismo version you could get but has since been discontinued, have to go second hand if you want one of those puppies.
From memory I recall seeing a C-west version posted up on the forums, but was awhile ago.
Good luck!
Here's some options...
Night Pager rear wing stay for bnr34
http://www.nengun.com/night-pager/rear-wing-spacer $358 delivered
Nismo rear wing stay for er34
http://www.nengun.com/nismo/rear-wing-stay-set (discontinued) but you can get the product code from here.
Then there are various universal options from this Uras item..
http://www.nengun.com/uras/wing-mounts
through to the electronically controlled versions (big bucks).
Hope that helps.
YEah that wing is the hottest wing off the R34 - I was actually thinking of getting it for my R33 but ended up going GTR wing.
You can get it from www.carmate.com - will set you back around $400 plus delivery when I last checked. Will look tough, but you will need a bodykit or it will not look nice on a stock R34 rear.
great work u guys. the nismos are definately the ones i'm after!! :D
the good stuff are always discontinued arent they.
howie, so with the product code do i just quote that to nissan they would be able to bring that in for me? correct?
You might be able to source nismo's from nissan themselves, but if they're discontinued they'll probably tell you that from my dealings with them. It's not the sort of item Nissan Australia keep stock of.
What i'd do is, keep an eye out on Yahoo auctions japan.. and then get slidewizeimports to bring it in for you. I see these things come up every few weeks on there.
online too eh howie? :D
guess what. i just found out that carmate sells them for AU$ 341.95 for the whole set unsprayed.
http://www.carmate.com/product_details.php...W&p_id=9941
i always thought the original gtt wing is reused and only the nismo brackets are required for mounting. i'll look at the carmate one now and decide if thats the way i want to go.
  • 7 years later...
 Share
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
