these are various parts lying aroung so make an offer anyway
r32 coupe tail lights $80 set
r32 side mirrors working $80 set
r32 glove box $20
r32 kick panels $5 each
r32 air con display $40
radio surround facia with cig lighter $40
instrument cluster gtr r32 with 90 000 kms $40
instrument cluster plastic surround $20
rear caliper and discs r32 gtst $50
r32 gtr standard front pipes $40
brand new lock nut set suit skyline $20
boot plastics nearly all of them $40
ignition column plastics $40
power window master switch off r32 $40
parts in fairfield
pick up preffered
https://www.sau.com.au/forums/topic/219724-r32-skyline-parts/
  • 1 month later...
Hey burko...You still have the gtr cluster surround and side mirrors for sale? Does the cluster surround have the clock in it? Also are the side mirrors black?
Cheers
cluster surround gone
mirrors are blue still avaiable though
  • 1 year later...
