Contact: Call 0413250250 or PM.
Comments: These parts were on my R32 GTR for a short time. Most parts I bought new and have only got 2000kms on them. Willing to ship all parts (buyer pays postage).
Item: HKS GT-SS Turbos
Age: 2000kms
Condition: Near new
Price: 2200
To Fit: All GTRs
Item: HKS S/S front and dump pipes
Age: 2000kms / 4 months
Condition: Near new
Comments: Entire length covered in thermowrap
Price: 750
To Fit: All GTRs
Item: Bosch 044 fuel pump in tank setup
Condition: Near new
Comments: Includes Croydon Autosport's GTR speed fittings to make intank installation easy
Price: 200
To Fit: Any car but fittings suited for intank GTR
Item: Nismo 550cc injectors
Age: 8000kms
Condition: Excellent
Comments: Injectors professionally cleaned and tested with new o rings (cost $150) 2000kms ago.
Price: 600
To Fit: All GTRs
Item: Nismo bolt on adjustable fuel reg
Condition: Near new
Price: 85
To Fit: All GTRs
Item: Justjap FMIC hardpipe kit with additional silicon elbow
Condition: Near new
Comments: Silicon elbow replaces rubber pipe between rear turbo and twin turbo factory pipe.
Price: 320
To Fit: R32 GTR
Item: 3" Catco metal cat with 5” body
Condition: Near new apart from some cosmetic scratches on the bottom side from normal road use
Comments: Bolton for GTR
Price: 250
To Fit: GTR
Item: HKS super sequential BOV.
Age: Unknown
Condition: Good working condition. Some cosmetic scratches on the body
Price: 150
To Fit: Any
Item: Blitz I-Color Spec R Boost controller with optional $110 Blitz Tempurature sensor
Condition: As new, still has the plastic cover on the screen
Comments: This comes mounted in a stealth custom mount to suit R32 if you want it. Temp sensor has never been used and still in packaging.
Price: 675
To Fit: Any
Item: Power FC with Hand controller
Condition: Near new
Comments: Tuned by Martin Donnan @ Willall running all mods listed here (cost $600). Conservative tune at 1.1 bar which i wanted for everyday use. Dynoed at 305rwkw. Comes with bracket to bolt straight in.
Price: 875
To Fit: 32/33 GTR
Will post up pics in next couple days
Thanks
Wegs
Edited by wegs
https://www.sau.com.au/forums/topic/219736-gtr-bolton-performance-parts/
First of the pics, more to follow :thumbsup:
Notes:
- Heat wrap on one of the hard pipes - this is the part between FMIC and TBody which is exposed to engine bay temps.
- Have a cover for the DSBC made of same material as mounting which hides controller.
Edited by wegs
I need the following stock parts to replace what i'm taking off. So if you have them in good condition we can do a deal.
Injectors (need to be free of leaking)
Front Pipe
Dump pipes
Turbos
Thanks,
Wegs
Edited by wegs
Are the front pipes compatible with an R33 GTR?
If so, I have the standard R33 GTR front pipe (also dump pipes). If you're willing to do some sort of a deal you can PM me.
Yes the front and dumps suit all model GTR's. I have another person looking at both front and dumps, will let you know if that falls through.
thanks
Wegs
Very interested in the 044 intank setup. Is that all I need to make it a direct replacement for my current pump? Whats involved in making it fit?
As you can see from the pics the install is quite straight forward IF you have the correct fittings on hand. First time around you'll need a couple hours to complete the job and a large ring clamp to hold it in the plastic cradle.
The fittings with my sale are quality earls parts - total price was $280. You can't just buy an 044 pump for $220 off the shelf and do the job.
Refer to following for instructions
http://www.skylinesaustralia.com/forums/Bo...p;hl=bosch++044
http://www.skylinesaustralia.com/forums/th...p;hl=bosch++044
Regards
Wegs
Edited by wegs
Comments: Sold
Comments: Sold
Parts still required and can be traded:
Injectors (need to be free from leaks)
Stock GTR Turbos
thanks for all the interest so far.
Wegs
The following items are now on hold pending deposit
Items still available
Item: Item: HKS GT-SS Turbos
Edited by wegs
    • Just install a grease nipple into the centre of the outer steel of the FUCA. Make sure the bushes aren't long enough to touch each other underneath that nipple. Cut a few mm off each if need be. Then you can push grease in there while it is all assembled. That was the very first thing I did (to all 4 ends) of the FUCAs on my 32 when I put Whiteline adjustable bushes into them. They would squeeze the grease out real fast, and I could squeeze it back in faster.
    • @GTSBoy I found the issue (sort of) when I took apart the bushing again, it was completely dry inside! When I experimented with it, all the grease would push out when I would compress the bushings. I wonder if this has anything to do with me putting in the poly bush first on both sides and then pushing in the metal barrel. Maybe I should have put in the metal barrel first then the rubber bushings so the spread pattern is different.   It's fixed (for now).
    • Just redid that entire job. 4 hours, but tightened everything properly. Had to jack the rotor instead of having the car on blocks as there was no room for the FUCA arms to tighten and the j arm. All good now. Cheers for the help!
    • I would sell those side feeds before you hydra-lock a motor. I won't say too much about Yellow Jackets because I'll hurt people's feelings, however ask those that tune RBs day in/out what they think of them.
    • The 1000ccs are side feeds but they're not currently installed, had my old factory ones in for leak testing purposes, only decided on them because front facing plenums and good top feed rail kits are out of my budget at the moment, are they really that problematic? Had a set of yellow jackets that lasted me 5 years, no real issues, only replaced them chasing this misfire issue that ended up not being ignition related 😄
