Hey skyline ppl! i thought i'd become a member here as im into all nissan imports and have a special attraction to skylines - it was my mates R33 GTS-T that introduced me to the magic world of RWD nissan imports!
i drive a 1997 180SX type X, custom number plates "LISTEN".. if anyone sees me on the road, gimme a honk and come for a run! ;)
at the moment, ive got around 160rwkw from the usual bolt on mods, but much more to come!
also, if anyone out there has an R32 and wants to sell some parts, let me kno! - im after the front brake assmebly (rotors and calipers) and a set of R32 GTS wheels!
if anyone wants to check out my ride, and my mates 200SX (he was at the UAS track day too), goto this site!
https://www.sau.com.au/forums/topic/21974-im-a-newbie/
    • If I drove to a typical petrol station, what would my choices of fuel be?
    • Just cut the bottom of the guard out. It's no longer got a big duct, to a sealed box, or a restriction. It has all the cold air from outside. Also, that cai you showed looks terrible. Bends are NOT good for go gos!
    • Like I said, "black magic" LOL In the end,  it is what it is, and hopefully, what this here knuckle head has done is an improvement and not a hindrance Not that I actually notice any negatives now, or that I will get any seat of the pants benefits when all is said and done, but best practice says I shouldn't be pulling intake air from the hot engine bay  Famous last words: I cannot see it being any worse than what it is at the moment 馃
    • If the gases flowing in those two tracts had the same properties, you could maybe use such broscience. But the exhaust has a different composition, different normal density, different actual density (because of different normal density, and mostly because of the massively higher temperature), and different viscosity (again because of much higher temperature). Consequently, all of the fluid dynamics parameters that matter, that you calculate from these inputs, such as the Reynolds number, friction factors (for wall friction) and so on, are all incomparable.
    • And we shall have to presume that Canada is the same?
