any input here would be much appreciated. i've done some searching and can't find any real answers to this. once or twice a year, i get a knocking noise coming from somewhere in my engine bay. i think it's coming from the passenger side somewhere. the sound comes up really badly at the start, it sounds like a hollow knock, like if you were to knock the engine with your knuckles. it goes in time with the revs and sounds absolutely terrible. thing is that if you take it for a bit of a drive . . . taking it easy on the revs and change gear really early, it seems to stay under control . . . to a point. then is gets better and maybe the next day or the day after it's gone all together.
this has happened once or twice a year since i got the car 5 years ago. it's a r33 gts s1. the first time it happend it was after i'd parked on a bit of a hill overnight, but the last few times that hasn't been the case. the last time i'd been mucking around around in the fusebox and hadn't started the car for only about a day. there doesn't seem to be any common factors that cause the noise.
any ideas?
https://www.sau.com.au/forums/topic/219746-knocking-sound/
that would be the little asian man that nissan put in your engine to make the car so good.. i think yours might be a little worn out and doesnt wanna be there no more.. take it to nissan for a replacement
https://www.sau.com.au/forums/topic/219746-knocking-sound/#findComment-3886013
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
