  • 1 month later...
Definatly do cam gears, on stock cams if need be
Injectors are easy; What HP at the motor do you want?
I would be very dissapointed if it did't make over 500bhp at the fly, 600 would be better. just no lag, 2k spool up would be good.
Im thinking about 800cc SARD injectors.
Is it just something about RB's that require massive injectors? Not having a stab at anyone, just posing the question...
My old man runs a TT 1UZFE, it makes 480rwhp @ 9psi and uses 340cc injectors at I think 70% or so duty cycle
So many people told me to go 550cc or bigger when building my RB25 and aiming for around 500hp at the fly (makes around 380 @ 18psi through built auto + 4200 stall)
Something to do with boost or engine design or something?
1UZ = 8 cyl so 8 cyls make 480hp, or 60 hp each.
RB = 6 cyl, so 6 cyls make 480hp or 80 hp each
rule of thumb, 6cc of fuel per hp.
so for the v8 480/8 x 6 = 360cc/min per cyl
for the 6 480/6 x 6 = 480cc/min per cyl
360 x 8 = 2880
480 x 6 = 2880
so both engines (if they are making the same power) require the same amount of fuel per minute, just the 1UZ spreads that over 8 injectors not 6.
does that answer ur question cactus?
edit: and as said above, a good tune can get rid of any low rpm drivability problems that might arise from oversize injectors, plus you have room to move in the future.
Edited by Kranker
360 x 8 = 2880
480 x 6 = 2880
Yeah that definitely makes a lot of sense, it kind of makes previous posts look about injector requirements excessive. to achieve say 480hp at the flywheel, which I assume is the correct measure when looking at the assumption 6cc fuel per hp, then 'theoretically' 550cc comfortably deliver the fuel requirements to make that 480hp. 1000cc as suggested is a little overkill...
I was more just wondering why so many people suggest massive size injectors for an engine that is not really making HUGE power :P
But thank you for the response!
R
 Share
    • From what I've seen and experienced first hand with those powder extinguishers, they're good to use to break a window and escape the car, and half the time then do f**k all to stop a fire. You just need much more than 1KG worth of powder. Not to mention, half the time it's an engine bay fire, and you can't easily, and do not want to completely open the bonnet, so you're left pretending to be an American Infantry... Spray and Pray baby!   And then 100% that shit is really destructive afterwards!   Realistically, those little ones at a race track might help you keep the fire from growing and give the fire marshal / truck a chance to actually get to you with their multiple large bottles.   For a road car, these days, prepare to deboard as quickly as humanly possible, and move to safety. Allow insurance to fix replace it (unless it's like a rare classic etc, then do nearly everything possible to save it!) Keep the little extinguisher with you to help protect other things around you from burning while you stand there singing "How can we sleep while our beds are burning?"   Secondly, powder extinguishers I freaking hate for indoor use, (this isn't really relevant to a car) as you will get a powder fog around you, and it can be disorientating.   When I did fire training when at BlueScope Steel, they have (had?) their own fire brigade on site. We did all the training, and at the end we were told, "If it's an indoor fire, and you need to use a powder extinguisher, we as the fire brigade would rather you just exit the building, you're more likely to get lost in the smoke and powder fog than do much help, so just GTFO" And pretty much that was what they said for most other fires too, grab extinguisher, if it's much more than paper in a bin fire, use extinguisher to get you and others out of the building to safety...   Part of me wishes when my Skyline caught alight many moons ago, I let insurance sort it out, instead of putting the fire out... part of me now says "But I've saved a classic before it was a classic!"
    • Hi all,  I have a older model of the Greddy Front facing intake on an RB25DET NEO Head. I've bought aeroflows fuel rail and injector kit (1000cc Bosche injectors) and I'm unsure if the fitment is correct. The injector o-rings fit in the intake hole but it's not snug. I can very easily rotate the injectors even when the fuel rail is mounted. The kit also came with multiple adaptors, they dont make it any more snug and using them raises the injectors up and i cant mount the fuel rail. I hope this makes sense I've asses a few photos.    Thanks so much guys.
    • So, to run the 4g aerials to the booster, I had to get access to the rear bulkhead....bit of a mission. Hot tip, don't offer to help change the rear shocks for a mate with a v37.... Remove seat base, 2 clips that slide forward to release it the it lifts straight out Fold down rear seat (pull in from boot) The side bolster of the rear seat is not connected to the middle parts that fold. To remove unbolt at the bottom bolt then push it up off the top hook Then there is a plastic surround behind the seat back, 2 pop out clips, 2 bastard clips, some swearing at it is out Pop the rear seat latch surround off Remove door surround lower trim then side trim  Remove c pillar trim - 4 clips, pull inwards not forwards Remove metal brace - 5 bolts 1 nut Then you have got to the rear strut top...what a pain!
    • If you really want squish back, you can have it put on the piston (at least to some extent).
    • Impressive. He's very very smooth.
