GTR-Ben Posted May 18, 2008 Share Posted May 18, 2008 Hey guys, I have mounted my 044 under the car with a surge tank (hate the smell and noise inside the car) and I have got a fuel pump control module from a GTR to drop the voltage to the pump at idle. I plan on using the lower idle 7V supply when my AFM output is under 2.5V, will this be ok for the Bosch pump? I guessed since it was ok for the stock GTR pump to run at this voltage then the 044 should to? The extra current won't heat it up if there is any? Thanks Sydneykid for the J Car voltage switch idea using this to switch to earth and supply battery voltage since the Powerfc does not have outputs to the control module i'm told. Link to comment https://www.sau.com.au/forums/topic/219777-bosch-044-external-pump-setup/ Share on other sites More sharing options...
GTR-Ben Posted June 3, 2008 Author Share Posted June 3, 2008 Ok so I wired it all up. The pump primed and then stopped Does not like trying to pump 50psi with only 7V behind it. Going to try upping it to 9V. It was pretty quite while it ran though.. Link to comment https://www.sau.com.au/forums/topic/219777-bosch-044-external-pump-setup/#findComment-3915134 Share on other sites More sharing options...
heller44 Posted June 3, 2008 Share Posted June 3, 2008 If possible, could you snap some pics of the instalation? Link to comment https://www.sau.com.au/forums/topic/219777-bosch-044-external-pump-setup/#findComment-3915279 Share on other sites More sharing options...
GTR-Ben Posted June 3, 2008 Author Share Posted June 3, 2008 If possible, could you snap some pics of the instalation? Only have pics of the tank etc setup under the car. The relays and wires are not that interesting 5 relays and a lot of wiring.. will be annoying if I can't use it.. Link to comment https://www.sau.com.au/forums/topic/219777-bosch-044-external-pump-setup/#findComment-3915327 Share on other sites More sharing options...
GeeTR Posted June 3, 2008 Share Posted June 3, 2008 (edited) The pump primed and then stopped what type of pump are you using for a lifter? Nice s.tank man Edited June 3, 2008 by GeeTR Link to comment https://www.sau.com.au/forums/topic/219777-bosch-044-external-pump-setup/#findComment-3916022 Share on other sites More sharing options...
STR8E180 Posted June 3, 2008 Share Posted June 3, 2008 wat car is that ? Link to comment https://www.sau.com.au/forums/topic/219777-bosch-044-external-pump-setup/#findComment-3916064 Share on other sites More sharing options...
Gts-t Posted June 4, 2008 Share Posted June 4, 2008 Pretty sure its a silvia, nice setup there ben Link to comment https://www.sau.com.au/forums/topic/219777-bosch-044-external-pump-setup/#findComment-3916244 Share on other sites More sharing options...
GTR-Ben Posted June 4, 2008 Author Share Posted June 4, 2008 (edited) Cheers Yep RB30 in a Silvia. Have a GTR lift pump in the tank. Overkill but I already had it in there.. The External pump was the one that stopped though Hope the Bosch Pump can run at a lower voltage.. took a bit of work setting it up. Edited June 4, 2008 by GTR-Ben Link to comment https://www.sau.com.au/forums/topic/219777-bosch-044-external-pump-setup/#findComment-3916255 Share on other sites More sharing options...
GeeTR Posted June 4, 2008 Share Posted June 4, 2008 (edited) Are you switching the pump to a dirty earth, or its supply voltage (with a few resistors) ?? Can you quickly feed it max juice to see if its a voltage thing, or something else? Not a one way valve hooked up in the wrong orientation? lol. I thought they'd heat up as well... Silvia with RB30 single... your crazy btw hahaha. Edited June 4, 2008 by GeeTR Link to comment https://www.sau.com.au/forums/topic/219777-bosch-044-external-pump-setup/#findComment-3916615 Share on other sites More sharing options...
GTR-Ben Posted June 4, 2008 Author Share Posted June 4, 2008 (edited) It is a volt thing. I can change the settings on my voltage switch and ground it to supply battery voltage and it goes fine. So the wiring is all working, just not enough voltage. Its regulated via a stock GTR voltage control module. These control 7, 9 and battery voltage via ground. As for increased current etc etc. It didn't seem hot even when it wasn't pumping but on.. I am no expert with the I=V/R and power output etc.. I guess because the pump is going slower it requires less amps.. so it won't get hot? If it was a problem, why would this system come out factory in a GTR? Edited June 4, 2008 by GTR-Ben Link to comment https://www.sau.com.au/forums/topic/219777-bosch-044-external-pump-setup/#findComment-3916997 Share on other sites More sharing options...
R31Nismoid Posted June 4, 2008 Share Posted June 4, 2008 Read the voltage/fuel pump thread... the link is in the Forced Induction Guide Should have just gotten decent fuel lines (stops the smell in cabin). I've seen them and they are tops, look cool too! Link to comment https://www.sau.com.au/forums/topic/219777-bosch-044-external-pump-setup/#findComment-3917593 Share on other sites More sharing options...
GTR-Ben Posted June 4, 2008 Author Share Posted June 4, 2008 Read the voltage/fuel pump thread... the link is in the Forced Induction Guide Should have just gotten decent fuel lines (stops the smell in cabin). I've seen them and they are tops, look cool too! I have probably read every thread on this board mate I like the tank under the car, would not have it any other way.. and I wanted a varying voltage signal to my external pump so it's not pumping 800hp worth of fuel between the rail and surge tank on idle.. and for the noise. Im confident at the 9V setting on the module the pump will work, remembering as soon as the car fires up and vacuum is applied to the regulator pressure is released as well as the battery will supply more voltage once the alternator starts working. The 7v feed may yet even work with the car running.. I ran out of time testing it in the weekend Link to comment https://www.sau.com.au/forums/topic/219777-bosch-044-external-pump-setup/#findComment-3917928 Share on other sites More sharing options...
STR8E180 Posted June 4, 2008 Share Posted June 4, 2008 (edited) Yep RB30 in a Silvia. i was gonna say!! where the hell did u find room for it i tried doing that kinda setup in my R32 GTR and i couldnt find any room wat so ever under the car to do some thing like that RB30 in a silvia??? dam!! any more details on the caR??? Edited June 4, 2008 by STR8E180 Link to comment https://www.sau.com.au/forums/topic/219777-bosch-044-external-pump-setup/#findComment-3918134 Share on other sites More sharing options...
GTR-Ben Posted June 4, 2008 Author Share Posted June 4, 2008 This is basically how it's wired. STR8E180: Skylines have the same space underneath.. just they have a hicas pump in that place. And who needs hicas anyway? I think it's Hicas... Widebody S13 with a RB30/RB26 in it. nearly 5 years work Link to comment https://www.sau.com.au/forums/topic/219777-bosch-044-external-pump-setup/#findComment-3918167 Share on other sites More sharing options...
GTR-Ben Posted June 4, 2008 Author Share Posted June 4, 2008 This is her. Link to comment https://www.sau.com.au/forums/topic/219777-bosch-044-external-pump-setup/#findComment-3918176 Share on other sites More sharing options...
STR8E180 Posted June 4, 2008 Share Posted June 4, 2008 wow thats some series respect!!! did u upgrade the suspension for the heavy front end??? also wat turbo are u using?":? i still got all the hicas junk under my GTR i just locked it up with a lock bar Link to comment https://www.sau.com.au/forums/topic/219777-bosch-044-external-pump-setup/#findComment-3918251 Share on other sites More sharing options...
GTR-Ben Posted June 5, 2008 Author Share Posted June 5, 2008 wow thats some series respect!!! did u upgrade the suspension for the heavy front end??? also wat turbo are u using?":? i still got all the hicas junk under my GTR i just locked it up with a lock bar Thanks mate. It has some aftermarket dampers.. nothing amazing but no problems with weight. Ballbearing Garret turbo. rated for 600HP or so. very responsive.. Remove all that Hicas junk then! bit of weight with all that. Link to comment https://www.sau.com.au/forums/topic/219777-bosch-044-external-pump-setup/#findComment-3919331 Share on other sites More sharing options...
T04GTR Posted June 5, 2008 Share Posted June 5, 2008 bosch pumps need full voltage all the time. plus they will draw about 4 times the currant as a stocker at 7v.. Link to comment https://www.sau.com.au/forums/topic/219777-bosch-044-external-pump-setup/#findComment-3920107 Share on other sites More sharing options...
T04GTR Posted June 5, 2008 Share Posted June 5, 2008 very nice setup but. i was having the room issue aswell. lol Link to comment https://www.sau.com.au/forums/topic/219777-bosch-044-external-pump-setup/#findComment-3920112 Share on other sites More sharing options...
Stagea Denmark Posted June 5, 2008 Share Posted June 5, 2008 Cheers Yep RB30 in a Silvia. Have a GTR lift pump in the tank. Overkill but I already had it in there.. The External pump was the one that stopped though Hope the Bosch Pump can run at a lower voltage.. took a bit of work setting it up. I have the same pump and setup in my Stagea, and have the pump at the same place, i run with 12v, i am pretty sure, you have to run it with 12v, but at this place, it is very noisy. Link to comment https://www.sau.com.au/forums/topic/219777-bosch-044-external-pump-setup/#findComment-3920423 Share on other sites More sharing options...
