Hey everyone,
I am new to the forum so if this has been discussed before im sorry for bringing it up again. I just purchased a 98 gtst m-spec, complete stocker and am in the process of picking out new goodies to make her go real quick. ive been trying to find a 3-3.5" turbo back system which is 'loud' as i love the sound the rb's make. If u guys could give me suggestions on such systems it would be much appreciated. i dont mind used systems either that are in good cond. thanks
https://www.sau.com.au/forums/topic/219803-loud-turbo-back-exhuast-systems/
  • Replies 40
Posted Images
trust power evolution II, 3.75" cat back (with cat replacement pipe) and about as loud as you would want, got one on my r33 gtr
however, i chose it because of its large diameter and eventually when i want more power it will still let the engine breathe. you should probably put some more thought into choosing a system rather than being as loud as you can get
Big Mike
guess it mostly depends on piping mine was a 3.5" it was pointless listening to music if u had the windows down coz you wouldnt hear it LOL it was crazy but yeah other than that titanium or just use a side exit pipe, no cat, nothing... ^_-
Edited by DaGr81
^^^^^^^^^+1 easy fix for a pointless question
if you looking at doing more down the track the spend the money on a bigger then 3" exhaust.... if not 3" is fine for conciderable power... and im not sure how differant it will be in sound at all..... power maybe.... you might loose a bit down low with the 3.75" exhaust... dont quote me on it but im pretty sure.
GO to exhaust shop
Ask for exhaust with no mufflers
loud
Pretty easy.
x2
Cheap, easy and loud.
Thats basically how my exhaust was... 3" all the way through... Just pipe. To a rear muffler. Beleive me the cops loved to pull me over!
screamer pipe...
also see if you can get on ACA and give us all an even worse name
lol! classic.. I just removed my entire exhaust from the dumps, replaced it with a piece of drainpipe from the side of the house and it sounds wicked! Didn't cost to much either!
Edited by Got Boost?
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
