Oil Filter Flow Direction
hi all, just checking that the direction that oil flows through an oil filter is from the outside to the inside? particularly on an sr20det?
also when running an oil cooler and filter relo kit you would have the lines organised in directions as follows -
from engine to filter, filter to cooler and cooler to engine, correct? cheers
I think Dave meant "anti drain back" valve, as all filters have relief valves (diverts oil around filtration element when the filter gets clogged) AFAIK
What do you mean by 'appropriate order' ?
Edited by GeeTR
as in, would you have the oil going to the cooler first or the filter first, i don't have an oil temperature gauge but ifi did i would want the cooler first as i would have the sensor attached at the oil filter and would want to know my "cooled" oil temperature, but seeing ahow i don't i thought it might make more sense to have the filter first to keep anything out of as much of the lines as possible. or does it just not matter at all
Ah right, sorry didn't bother as Dave answered you :laugh:
I think you'll find ppl always run the filter (and a oilstat if being used) before the cooler.
I know what your saying about temp sender location, but the oil eventually ends up in the sump, which is effectively a wet sumps "reservoir" A sender in the sump would give the hottest temp the oil should ever reach; hence why some ppl prefer that location.
Much of a muchness i think.
i suppose you really would be wanting to monitor how hot the oil is coming out of the engine not how 'cool' (yet still obviously very hot) it is going back in, i don't know why but i had two mechanics tell me that the oil goes into the centre of the filter first and then out of the outside so i hooked my lines up accordingly, but looking at it now it doesn't really matter i suppose
^^ Hrmm all the cars iv worked on have engine oil go into the outer, then out from the center. Time to smack your mechanic :laugh:
EDIT: Found a nice little DIY on SAU HERE for ya.
Any questioning is rendered moot, as you can just have someone keep on eye on both lines, when you crank the car first time; then attach as appropriate.
Edited by GeeTR
kick your mech in the balls.... that setup will create flow issues and result in near ZERO oil pressure if it has a thermostat like a GREDDY cooler etc
 Share
    • I have a radium fuel rail on my Greddy manifold and used the supplied radium fuel injector to manifold adapters (The round green things pictured). I did always wonder if you could just go ahead and use the second lower hole like you're doing... Wouldn't thicker o-rings solve your issue?
    • From what I've seen and experienced first hand with those powder extinguishers, they're good to use to break a window and escape the car, and half the time then do f**k all to stop a fire. You just need much more than 1KG worth of powder. Not to mention, half the time it's an engine bay fire, and you can't easily, and do not want to completely open the bonnet, so you're left pretending to be an American Infantry... Spray and Pray baby!   And then 100% that shit is really destructive afterwards!   Realistically, those little ones at a race track might help you keep the fire from growing and give the fire marshal / truck a chance to actually get to you with their multiple large bottles.   For a road car, these days, prepare to deboard as quickly as humanly possible, and move to safety. Allow insurance to fix replace it (unless it's like a rare classic etc, then do nearly everything possible to save it!) Keep the little extinguisher with you to help protect other things around you from burning while you stand there singing "How can we sleep while our beds are burning?"   Secondly, powder extinguishers I freaking hate for indoor use, (this isn't really relevant to a car) as you will get a powder fog around you, and it can be disorientating.   When I did fire training when at BlueScope Steel, they have (had?) their own fire brigade on site. We did all the training, and at the end we were told, "If it's an indoor fire, and you need to use a powder extinguisher, we as the fire brigade would rather you just exit the building, you're more likely to get lost in the smoke and powder fog than do much help, so just GTFO" And pretty much that was what they said for most other fires too, grab extinguisher, if it's much more than paper in a bin fire, use extinguisher to get you and others out of the building to safety...   Part of me wishes when my Skyline caught alight many moons ago, I let insurance sort it out, instead of putting the fire out... part of me now says "But I've saved a classic before it was a classic!"
    • Hi all,  I have a older model of the Greddy Front facing intake on an RB25DET NEO Head. I've bought aeroflows fuel rail and injector kit (1000cc Bosche injectors) and I'm unsure if the fitment is correct. The injector o-rings fit in the intake hole but it's not snug. I can very easily rotate the injectors even when the fuel rail is mounted. The kit also came with multiple adaptors, they dont make it any more snug and using them raises the injectors up and i cant mount the fuel rail. I hope this makes sense I've asses a few photos.    Thanks so much guys.
    • So, to run the 4g aerials to the booster, I had to get access to the rear bulkhead....bit of a mission. Hot tip, don't offer to help change the rear shocks for a mate with a v37.... Remove seat base, 2 clips that slide forward to release it the it lifts straight out Fold down rear seat (pull in from boot) The side bolster of the rear seat is not connected to the middle parts that fold. To remove unbolt at the bottom bolt then push it up off the top hook Then there is a plastic surround behind the seat back, 2 pop out clips, 2 bastard clips, some swearing at it is out Pop the rear seat latch surround off Remove door surround lower trim then side trim  Remove c pillar trim - 4 clips, pull inwards not forwards Remove metal brace - 5 bolts 1 nut Then you have got to the rear strut top...what a pain!
