ok well heres a pik of my car, so i guess u can base ur judgements on that :laugh:
Luke ENR34 - i love the Rays ones, but i cant afford 5grand right now just for rims with no rubber.
My rims got pinched off my car, I had volk SE37k's, so I am now looking for somthing in my price range (Max $3500 inc Tyres)
Ferah, I like your car- however, some recommendations...
I don't think these rims will suit your R34 as there's too much gap between the spokes - you will find that it will make your car look really small and your rims will tend to look a bit out of place. Definitely get black spoke rims, but get something like Work Rims - will suit a R34 perfectly - get copies if you must. Rims is the final piece to the car - I'd rather save up and do it right.
Also, the black OEM r34 bonnet doesn't look nice - I would go carbon fibre with vents (just the subtle ones) and lose thos foglights, then move your rego plate to the side - it will look angry then. Just my 5 cents.
It's looking good - keep up, Ferah!
My bonnet is full carbon fibre, its not black. Just looks like that in the pik :laugh:
and i dnt wana move my plate into the side as its illegal.
But yeah ur definantly right about the black rims
and dont go for a cheaper option...
i wanted SSR professor sp1's with black spokes and dish... but they cost the bomb...
so i bought some aussie spec black 5 spoke speedy inferno's... nice, but as they weren't 100% what i was after...
2 months later they were sold and the SSR's were on the car...
could have saved a grand and a half if i had done it right the first time
The black spokes would match your panda style black bonnet and chin spoiler w/white car theme
and the titanium lip would add to that 'wow' factor if you wanna impress some lancer/civic schoolboys.
Just as long as there's a decent amount of dish and a good offset it will come off quite nicely,
I settled for LMGT3's on my r34, actually looks pretty good, don't have the coin for LMGT4's AND tyres :)
Edited by Yo-Yo
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
