Since the hi-jacking of my N1 block thread (dont get me wrong - if N1 oil pumps are a hot topic, then I am glag I could initiate some dialog..)
I thought I would try a different tact for my next topic...
if one was building a RB26 for response - what woild you do... feel free to explore (but not limit youself to) Turbos, Compression ratio, Cams and Cam Timing. I would like to keep this topic about RB26 if possible - 2.8 etc have there obvious benifits... but lets just say we want to stick with 2.6 for now...
Want to make as much power / torque down low as possible.
So building a good responsive RB26 for a mostley street car...you would.......
(your opinion goes here)
Looking forward to the banter again. Love this forum :)
Edited by Antimatter
https://www.sau.com.au/forums/topic/219857-building-an-rb26-for-response/
Looking forward to the banter again. Love this forum :starwars:
im running n1 turbos and they are extremely responsive for the street, i couldnt believe how progressive the power delivery is......they dont seem to run out of puff as well, and will hold boost nicely all the way to 7000rpm:)
I notice your other thread made mention of 400rwkw?
If going for response, it's the GT-SS/ -7's as a the combo of choice. But you wont see anything like 400rwkw. 320rwkw is about it.
The hold till 8000rpm when setup correctly.
With injectors, AFM/PFC & nice rebuild and a tidy up of the head and so on… its basically like having the RB26 with factory turbos, but it'll make you the extra 60-80rwkw with 20+ psi making it feel very meaty. Provided your tuner knows how to play with cam gears and so on.
Just whatever dumps and you could increase the comp slightly being fuel in todays world is a bit better here in AUS compared to 10-15years ago.
Hey Ash
I did mention 400kw.... and I would love this + response, but I also understand that without going to 2.8 or 3.0 It is going to be a compromise. Just curious to see peoples experience with response and there own setups....
I have seen some really good compromises with Apexi (AX Series) Turbos seeing around the 370kw mark - however these are sadly discontinued.
on the other hand... how responsive can -5's be "made to be" with the right cam timing and compression?
Steve
Rb26 eh?
Response only, no power goal.
Rip off the turbos, increase the compression ratio to 10.8:1 with some RB25DE pistons, lighten the flywheel, fit the 4.35 diffs out of an R32 GTS4 and fit some tube extractors.
Throttle response with the six throttle body induction should be pretty instantaneous.
Well you did ask...........
I spose I did :D
Now can I have that and 350kw?
:w00t:
Rb26 eh?
Hey Ash
Steve
-5's aren't too bad.
Snowmans car is one of the signature cars for it, its sooo much nicer than it was a few years ago and thats just R&D really (Racepace)
And considering your Melb - its probably the place i'd be going to bounce some ideas around and go for a buzz in a few of the Vic guys cars with the -7 and -5 and see for yourself which set-up suits best.
Having owned GTR's that are stock (211rwkw), mild ( 280rwkw), pretty fast (370rwkw) and the best (460rwkw), I dont think I would ever opt for anything other than 460rwkw again. I am currently driving a GTR with 225rwkw and hating it, its for sale.
Again, this is just an opinion, and all of those cars were 100% street driven, everyday, never been on a track with a GTR. In my opinion, the difference between lag and response is gear selection.
For the sake of your thread, the 370rwkw was an HKS 2530 set up.
Have heared 2530's and -5's are pretty similar.... or is that GT-RS and -5's?
Been told that -5's are in pretty short supply at the moment too....
I guess the turbos will be the big factor - but if I were building an engine.. "slightly" higher comp.... clean up the ports... and I am on the right track?
I understand a good tune (both ECU and cam timing) goes a long way :w00t:
I understand a good tune (both ECU and cam timing) goes a long way >_<
For me i would..
Head:
Port and polish
260' Cams with good lift
Adjustable cam gears (and dialled in properly)
Bottom End:
9.0:1 Compression Forged Pistons
Forged Rods
Treated crank
Turbos:
HKS 2530 or Garret 2860 -5's
With 1.6-1.9 Bar boost I would expect 400kw atw easily. Im running 2530's with Tomei 260s making 360kw atw on 1.3bar, stock bottom end and no head work. I get full boost around 3,800rpm.
Edited by Blue_GTR
contrary to popular belief, a single can give you the results you're looking for.
Maybe
Fact of the matter is the thread starter is in Vic. Big singles are a no-no down here these days
Low mounts all the way due to the EPA/Police etc
SAU Vics catchcry:
"go see Ben"
(and fair enough too)
:P
... that is a very sexy graph, whats it like to drive?
Here's my latest dyno graph. Racepace -5's set-up.
If this is what you want then go see Ben. If you want / expect even better results on an RB26 then good luck with that.
    • Lets keep this going , Spotted this very stock V35 in Penrith and also saw a nice R32 FLY past me on Castlereagh rd , sounded really good.
    • Great work! Give it a clean up with some Emery paper, and I'd run a thread die over the threads too to clean them up. It will make reinstall much easier, and also life easier for the next time it needs to come out.
    • I'm not a fan of high humidity, it's one reason I don't mind being further inland out Ipswich, except the last 3 odd years, the drought broke, and it won't stop raining, which is making the humidity nearly unbearable when the rains are in during summer! For me, my body hates the cold, once the cold sets into my body, I'm totally screwed. I end up with severe muscle spasm in my back/shoulder muscles, and it feels like someone is trying to tear the muscles out. I have no issues with it getting stupid hot, so long as the humidity goes away. So the last 3 years as above, have been woeful! Ha ha. However, June 1st, and I'm only just converting from shorts and a tee, to long pants and a t shirt. And that's mainly as it's a bit wet and miserable and I wanted to work on a car.
    • I much prefer colder weather to hot weather, and especially prefer cold to hot and humid, Goulburn does gets pretty warm in the hotter months, but, I've found the humidity there is not as painful as even Sydney, the humidity up north is to oppressing for this old rooster  In saying this, it does get rather "nippy" in Goulburn for early morning, late in the evening walks, but nothing that a layer or two, some thermal gloves, and a beanie doesn't fix to make it an enjoyable experience, which is much more bearable to me than the oppression of heat and humidity,  especially at night when your trying to sleep If I recall correctly, a "wise man" once said that the "Southern Tablelands" was gods country, and I will not argue that point with him for the fear of a "permaban" LOL In car part related news: My intake is currently in Botany getting processed for the last leg of its shipping journey to my door
    • Had a go at the stuck crush tube this afternoon. Tried things like grips and a chain wrench first but wouldn't just twist straight off. So got to work with a drill. Started small and kept a depth stop on to make sure I didn't drill into the bolt. Made a line of drill holes all the way up and enlarged them. Then a combination of chisel and Dremel to split it all the way up. Levered the split to get oil in there and eventually it gave a bit while levering. Worked it back and forth with loads more oil till it was spinning freely, then with grips I could work it downwards and off. And no significant damage to the bolt (not by me anyway - just the 27 years of rust)
