I recently got my car tuned with 'response' in mind.
I have -7's, ID2000's on pump 98 and stock internals, and this was the result:
1476343_10153636999910301_502255709_n.jp
Does this graph represent a "responsive" engine? Certainly feels responsive, as in there is very little lag when going full tilt.
Obviously it has a long way to go as far as HP is concerned, but would that response be sacrificed if boost pressure was increased?
It all depends on the tuner. I get full boost by around 3900RPM for my 320KW. Though i dont have stock internals. Is there a reason you got ID2000? Large injectors for the turbos you are running. Also what AFM are you running? that to me looks like stock AFM maxing out.
Running ID2000's because I will eventually run e85, just ran out of funds to flexfuel setup. Everything else is ready to go though, twin 044's and surge tank etc.
As for AFM's, I switched from a vipec to a haltech platinum pro, so it shouldn't be relying on AFM's as far as I know.
Interesting. Could possibly just be the age of the motor.
Edited by Anfanee
What would you be expecting? We did ask for a reliable tune. When I decide to rebuild I will chasing HP but at this stage I want it to last as long as possible.
Wouldn't know without looking at the actual health of the engine. Your tuner would know what they are doing. Best to keep it as safe as possible. My tune isn't overly "Safe" its a bit agressive but i have had a ground up rebuild.
That is a nice curve though. From what i've seen most cars run around the 270-290 mark that are still stock internals.
Honestly until you even think about doing internals i wouldn't put in on E85. Has the motor been rebuilt previously? if not 20 years is a long time worth of thrashing haha.
I should have taken some photos of what my motor did to itself...
Edit: as zebra said. It's fine. Im pushing 21PSI through mine...
Edited by Anfanee
Shit that's good for standard actuators. I can't believe they still hold boost that well.
it's more the way the cams are set, making better use of the air it gets meaning the turbos don't have to working as had
a good quality boost controller doesn't hurt either
Haha,don't know,hoping to fix it with next tune,that tune just then was a lazy tune I think,took him an hour
what mods have you got done ?, cause yeah that's not great at all, what boost is that ?
cam gears ? if not get some
  • Like 1
    • Grind them off, drill them out. Repair any rust on the other side. Start again from scratch.
    • Big R34 GTR parts cleanout. I have a lot of stuff collected over the last 14 years and my missus is giving me hard time. Make my life easy.   Nismo GT carbon fibre diffuser fins (discontinued)  NEW  $2900 Garage Defend Stingray canards carbon fibre  NEW  $1300  Top Secret G Force carbon fibre front diffuser  NEW  $2000  Haltech Elite 2500  NEW  $2500  Haltech Platinum Pro R34 GTR   USED  $1400  Apex’I power FC D'jetro + hand controller R34 GTR   USED  $1400  Nissan OEM BNR34 ECU  USED   $1000  HKS EVC 6  USED  $600  Blitz dual SBC ID boost controller.  USED  $350  TRE 255 LPH Fuel pump  NEW  $100  Fujitsubo  Super Ti exhaust  USED  $2700  Tomei Expreme Ti exhaust  USED  $2000  Trust stainless steel front pipe  USED  $1000  Apex’I super suction kit  USED $400  BC BR coilovers  USED  $600  Hardrace front upper camber kit. USED  $300  Garret 2860-5 turbos –  one good, one needs reco USED  $1000  Nissan OEM Toshiba MFD Screen replacement  NEW  $450  Nissan OEM BNR34 Series II front passenger seat  USED (mint) $5000   Nissan OEM BNR34 front bar in TV2  USED  $1000  Nissan OEM BNR34 front lower air spoiler  USED  $900  Nissan OEM BNR34 front lower air spoiler (painted)  USED  $900  Nismo front indicator (clear) USED  $80 Nissan OEM BNR34 radiator  USED $500  Nissan OEM BNR34 turbos  USED  $500  Nissan OEM BNR34 intercooler USED  $800  Nissan OEM BNR34 front swaybar   USED  $500  Nissan OEM BNR34 intake pipes   USED  $400    Also have a square set of uber rare Volk CE28n in 19*10 +22. Not really keen to sell these but make a high enough offer and maybe I will. If you don't know how much these usually sell for don't bother.   PM for pics.  Pickup Chadstone VIC or postage at buyer's expense.
    • Thanks Mate, I did know you could do that but i know there is a pump out there that you can bolt on and it all lines up. I was told about it and then forgot the model, I figure if i am pulling it apart i will just put a new one on
    • You can also remove the veins from the HICAS portion of your existing pump.
    • Trying to swap the rear subframe on my R34 and can't remove the L-shaped stay brackets between the front subframe mounts and the sill/chassis. I'm in the UK so rust is a problem. I've used loads of WD40 and then Tunap 103 for days beforehand. I backed off the bolts forward a bit, backward a bit repeatedly for ages to try and avoid snapping. They have all moved a few full turns. The one I've spent most time on has come loose and I can turn with fingers, and it will pull down and push up 2-3mm. But it won't come out. I can tighten it back up and loosen it off again repeatedly but it still won't come out. I assumed there's a captive nut inside but if that's broken loose then I can't understand why I can always tighten the bolt back up - I'd expect it to just spin both ways. Any ideas what's happening here? I can't visualise what's inside there to cause this.
