i tried on 18s yesterday and they were scrubbing on the inner side on the arm that goes up to the camber adjuster(front), i would need to run 5mm spacers to fit them, back was fine heaps of room. these were 30 offset.
This bracket it was rubbing on only seems to flare towards the outside of the car as it gets higher, so bigger rims would have even more trouble?
Please if you know , reply here. If your just guessing, dont bother and you might just learn something.
ps, please no comments about 20s are too big or ugly or whatever, i dont care. Im just interested to know this.
thanks Dave
Edited by dave_1
https://www.sau.com.au/forums/topic/219859-20s-on-a-r32-possible/
yes bigger rims will have more/frequent rubbing.. you may also require some rubbing.. the amount of rub will also be affected by weight in the car (more ppl) and bumpy roads etc.. it'd be hard to get them not to rub.. also you will most prob get problems on tight turning (at least on full lock) as the tyre will rub on parts inside the wheel cavity..
ps.. 20's look shmick >_< fill in the gap.. however it's also worth noting that it's not legal (apparently so i've been told) that you cannot put tyres on that are 2" above standard ie. 19's is the max on 17's as standard.. *Could be wrong, just what i've been told by roadworthy mechanics*
what offsets/width?
if ur scrubbing on the inside and need a 5mm spacer then same width/offset is gonna do the exact same thing.
^ the rule is for rolling diameter which includes ur tyre profile as well. doesn't just go on rim diameter. its stock rim diameter + profile vs new rim diameter + profile.
but yes, 20's r gonna be over obviously :)
ps.. 20's look shmick :D fill in the gap.. however it's also worth noting that it's not legal (apparently so i've been told) that you cannot put tyres on that are 2" above standard ie. 19's is the max on 17's as standard.. *Could be wrong, just what i've been told by roadworthy mechanics*
the first part is correct, except about the 20's looking good lol. standard rims on a r32 are 16" however, so 18" is the limit. there a new law coming in, apparently its already in SA where u can go as large rims as u want as long as it doesnt affect the overall diametre by some small amount. but i wouldnt risk it.
as for 20" rims clearing, it is possibly with the right width, offset, tyre size/profile etc. but as mentioned before, the law says no, and so does baby jesus.
  • 3 weeks later...
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to more wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
