i tried on 18s yesterday and they were scrubbing on the inner side on the arm that goes up to the camber adjuster(front), i would need to run 5mm spacers to fit them, back was fine heaps of room. these were 30 offset.
This bracket it was rubbing on only seems to flare towards the outside of the car as it gets higher, so bigger rims would have even more trouble?
Please if you know , reply here. If your just guessing, dont bother and you might just learn something.
ps, please no comments about 20s are too big or ugly or whatever, i dont care. Im just interested to know this.
thanks Dave
Edited by dave_1
https://www.sau.com.au/forums/topic/219859-20s-on-a-r32-possible/
yes bigger rims will have more/frequent rubbing.. you may also require some rubbing.. the amount of rub will also be affected by weight in the car (more ppl) and bumpy roads etc.. it'd be hard to get them not to rub.. also you will most prob get problems on tight turning (at least on full lock) as the tyre will rub on parts inside the wheel cavity..
ps.. 20's look shmick >_< fill in the gap.. however it's also worth noting that it's not legal (apparently so i've been told) that you cannot put tyres on that are 2" above standard ie. 19's is the max on 17's as standard.. *Could be wrong, just what i've been told by roadworthy mechanics*
what offsets/width?
if ur scrubbing on the inside and need a 5mm spacer then same width/offset is gonna do the exact same thing.
^ the rule is for rolling diameter which includes ur tyre profile as well. doesn't just go on rim diameter. its stock rim diameter + profile vs new rim diameter + profile.
but yes, 20's r gonna be over obviously :)
ps.. 20's look shmick :D fill in the gap.. however it's also worth noting that it's not legal (apparently so i've been told) that you cannot put tyres on that are 2" above standard ie. 19's is the max on 17's as standard.. *Could be wrong, just what i've been told by roadworthy mechanics*
the first part is correct, except about the 20's looking good lol. standard rims on a r32 are 16" however, so 18" is the limit. there a new law coming in, apparently its already in SA where u can go as large rims as u want as long as it doesnt affect the overall diametre by some small amount. but i wouldnt risk it.
as for 20" rims clearing, it is possibly with the right width, offset, tyre size/profile etc. but as mentioned before, the law says no, and so does baby jesus.
  • 3 weeks later...
    • What could be causing my clutch problem besides a bad master or slave then? Both those parts are new
    • Just came across this, but in QLD I start leave again in 2 weeks, if it is still available I might drive up and check it out Unless, @MBS206 do you live near here????, if so I could hit you up with a finders fee https://www.gumtree.com.au/s-ad/hope-island/auto-body-parts/nc-mx5-factory-hard-top/1328976391
    • My hold point for future mods is that I want a OEM detachable hard top first, but, finding one is a pain, MX5 Mania are looking for one for me, but, as hens teeth are more common, finding one in Australia is proving problematic  I can get a OEM one from overseas, hell, you can still get new ones in 'Merica, but, shipping is a absolute killer and I cannot justify the cost, or the risk of it being damaged during transport As for the aftermarket hardtops, whilst they do the job of being a hard top, and are fine for a track car, they don't seal well (read: leak like a sieve in the rain), and you need a plastic/poly rear window, plus they are a bolt in option only and not made to be easily removed I liked how the hard top on my NB could be fitted, and removed, by myself, in less than 5 minutes I know it sounds bad, but I'm waiting for someone to write off a car with one so I can swoop in on their pain, it will go to a good home though, so my guilt of this is tempered
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
