Hi all,
I know there are many threads re the factory screent, but i have tried searching many threads - and cannot find a simple answer to the question im after.
The factory touch screen that the S2 Stags come out with - do they have an AV input on the rear of the unit??
What connector is it?? RCA??
i want to install a dvd/dvix player replacing the factory mini disk/radio deck with one that will pick up Ausie stations as well as be able to play DVD's and DIV'X's through the factory screen - and I have checked that the deck I want to get does output in NTSC.
I want it all neat and all cables at the rear of the units - I dont want cable from the front running to the rear??
If anyone has a pic of the rear of the unit it will be most helpfull!!!!
thanks!! :starwars:
https://www.sau.com.au/forums/topic/219874-s2-screen-av-input-on-rear/
there are NO AV inputs on the back of the screen, only wires. AV1 are the mini-plugs on the front and AV2 are the RCAs at the rear of the car. If you are handy with wiring you can rewire the video AV1 plug internally into an RCA plug coming out the back of the unit.
Thanks for your reply chook!! :w00t:
but I didnt hear what i was hoping to hear!! LOL
So my question now is - is it possible to do what I want to do....???
I never knew I had AV2 RCA's at rear of car?? where are they?? Is that an input for Video into the screen??
If so could I just run an AV cable from the back, up to the front and into my Video OUT of my DVD player??
yes, just run the RCA from your dvd through centre console, under back seat, under rear floor panel to left rear door pocket. There you will find the factory TV tuner on the right as you look in with RCA inputs on the bottom. You may have to remove shroud or CD stacker to access the plugs on the tuner. Use a good quality shielded RCA cable. Extra info here, in case you havn't seen, http://www.skylinesaustralia.com/forums/St....html&hl=tv
Now that is more along the lines of what I wanted to hear before spending cash for a new deck!! :D
speaking of that CD stacker - I havent been able to get it working - ahh well... wont need it when I can use my USB stick for music on the new deck!! :)
so that stacker will be ripped out anyways!!
cant wait for the weekend now!!
thanks again chook!! :w00t:
I also just changed to an ALPINE USB deck, no more discs.
FYI, I have found that a 4.0 meter RCA cable is the ideal length to run to the raer tuner.
i'll be trying to install the deck tomorrow.... i'v only had a quick look near the cd stacker - and cant see any way to take it out or get to the AV input......
do i need to take out that floor panel where the stacker is...???
i'll take some pics as i do it for any one else planning to do a similar thing....
remove center floor panels,
left floor panel,
rear black floor facia panel,
top side trim: remove rear seat release handle surround (pry out small button clip inside) , 2x10mm bolts (behind hangers), unclip top trim so its loose.
bottom side trim: remove 2 rear push pins, remove side flap door, remove clips on inner shroud above stacker.
Pull out lower trim so you have room to work.
Remove plastic inner shroud.
Remove cd stacker (3 bolts and a plug) and gently place in garbage bin.
You can now feel 3 RCA plugs under tuner, rear most plug is Video, then Right audio then left.
ok.... when organising a Wedding, you have sweet F**k All time to do anything else.... so i've been driving my car with everything dissmantled and no music/radio for a week..... (luckily i had the turbo to listen do :( )
but, i finally found some time last night and put it together.... and it works a Treat!!!!! Flick the deck over onto NTSC - turn it off, back on again for the NTSC to take effect and bingo!! DVD, DIVX, radio, etc....
Didnt have a chance to take pics last night.... but will try put some up today after work!!!
One quick question..... where's the best place/way to run a power cable for an amp....??? I'm thinking of putting a sub in the back... but couldnt figure out where to run the power cable through the firewall.... any suggestions...?? best/easiest way...??
Follow your accelerator cable towards the front right gaurd to the firewall where you will find
the big rubber boot/grommet, and push that sucka through.
Small hands helpfull here, then pull it though around the footwell area, under the carpet etc....
Or
Go from inside of the car to the upper right of the drivers footwell where you can just see the rubber boot/grommet and accelrator cable come through the firewall and push it through there, wander around to the engine bay side and pull it through. i did it this scond way and used a bit of coat hanger to hook the cable and pull it through enough to reach the battery.
Thought i'd post up a few pics of the final product.
Installing the deck is pretty much same steps as installing a deck and there's threads on it here.
The other pics are of where the screws are to take out the CD Stacker (make sure you gently place it in the bin :D ), and you can see i've half taken out the screws in the pic.
and another pic of where the AV input is for the screen, its in front of the CD stacker and I took a pic underneath of it which shows the RCA inputs.
Hope this helps others as Chooks instructions definitely helped me!!!
Fulock, are you able to play a PAL dvd thru this baby as is?
Yes I can! :(
the paused R34 in my pic above is from Too Fast Too Furiouse - that little 10mins clip at the start before the actuall movie starts....
Last night I was watching a divX disk full of TopGear!! :D
  • 2 months later...
i did the exact same thing today. Wired the headunit's parking brake wire to the earth so that it'll work with handbrake off.
However it seems the car has a sensor that detects when the car is put out of P or N... And turns the screen off when driving and just has a message on the screen (in jap, I assume says something like "screen disabled while vehicle in motion")
Does anyone know how I can make it so I can have the screen on constantly??? It's annoying cause I'm taking the car to Canberra in a few weeks and the DVD's there for my passengers to watch on the drive over and back.
The screen overide is quite complicated, requires a piece of aftermarket equipment, PM sent
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
    • Careful with posts like that around here without the flame suit on @cobo_11! 😂😂 My 330i journal is on here too. That car was so good and super reliable. We still have a 130i in the family which is almost identical to the 330i and easier to find in manual. It has also been almost faultless over the 6 or so years in the family.  I used to want an M car a lot more than I do now but if I'm honest and without trying to sound like a wanker, I can get such good performance and handling out of my 335 without needing to worry about all the crap that goes along with M car ownership. I don't need to worry about my bearings or subframe issues or the cost of replacing brakes or suspension or whether it has been impeccably maintained. And I can leave it places and not get upset when it's always filthy.
    • A pretty cool little feature discovered while restoring my seats.
    • Great write ups / details / photos. I'm sort of on the road to E90 ownership (325i or 330i), haven't hit the fork in the road yet "Yes" | "No", and some of the issues you've faced have me nervous for the age these are getting to nowadays (that wiring, jesus), but I'm guessing the pro's of ownership are still outweighing the con's? Of course, if the bloody tattslotto ROI actually went my way...E90 M3. And I'd have the cash to do all the extra lovely maintenance THOSE require. 😄
    • They sure do, great for when you need to chuck a sickie 😅   You should definitely give the beast a squirt on the track, great to enjoy the car
