Hi all,
I know there are many threads re the factory screent, but i have tried searching many threads - and cannot find a simple answer to the question im after.
The factory touch screen that the S2 Stags come out with - do they have an AV input on the rear of the unit??
What connector is it?? RCA??
i want to install a dvd/dvix player replacing the factory mini disk/radio deck with one that will pick up Ausie stations as well as be able to play DVD's and DIV'X's through the factory screen - and I have checked that the deck I want to get does output in NTSC.
I want it all neat and all cables at the rear of the units - I dont want cable from the front running to the rear??
If anyone has a pic of the rear of the unit it will be most helpfull!!!!
thanks!! :starwars:
https://www.sau.com.au/forums/topic/219874-s2-screen-av-input-on-rear/
there are NO AV inputs on the back of the screen, only wires. AV1 are the mini-plugs on the front and AV2 are the RCAs at the rear of the car. If you are handy with wiring you can rewire the video AV1 plug internally into an RCA plug coming out the back of the unit.
Thanks for your reply chook!! :w00t:
but I didnt hear what i was hoping to hear!! LOL
So my question now is - is it possible to do what I want to do....???
I never knew I had AV2 RCA's at rear of car?? where are they?? Is that an input for Video into the screen??
If so could I just run an AV cable from the back, up to the front and into my Video OUT of my DVD player??
yes, just run the RCA from your dvd through centre console, under back seat, under rear floor panel to left rear door pocket. There you will find the factory TV tuner on the right as you look in with RCA inputs on the bottom. You may have to remove shroud or CD stacker to access the plugs on the tuner. Use a good quality shielded RCA cable. Extra info here, in case you havn't seen, http://www.skylinesaustralia.com/forums/St....html&hl=tv
Now that is more along the lines of what I wanted to hear before spending cash for a new deck!! :D
speaking of that CD stacker - I havent been able to get it working - ahh well... wont need it when I can use my USB stick for music on the new deck!! :)
so that stacker will be ripped out anyways!!
cant wait for the weekend now!!
thanks again chook!! :w00t:
I also just changed to an ALPINE USB deck, no more discs.
FYI, I have found that a 4.0 meter RCA cable is the ideal length to run to the raer tuner.
i'll be trying to install the deck tomorrow.... i'v only had a quick look near the cd stacker - and cant see any way to take it out or get to the AV input......
do i need to take out that floor panel where the stacker is...???
i'll take some pics as i do it for any one else planning to do a similar thing....
remove center floor panels,
left floor panel,
rear black floor facia panel,
top side trim: remove rear seat release handle surround (pry out small button clip inside) , 2x10mm bolts (behind hangers), unclip top trim so its loose.
bottom side trim: remove 2 rear push pins, remove side flap door, remove clips on inner shroud above stacker.
Pull out lower trim so you have room to work.
Remove plastic inner shroud.
Remove cd stacker (3 bolts and a plug) and gently place in garbage bin.
You can now feel 3 RCA plugs under tuner, rear most plug is Video, then Right audio then left.
ok.... when organising a Wedding, you have sweet F**k All time to do anything else.... so i've been driving my car with everything dissmantled and no music/radio for a week..... (luckily i had the turbo to listen do :( )
but, i finally found some time last night and put it together.... and it works a Treat!!!!! Flick the deck over onto NTSC - turn it off, back on again for the NTSC to take effect and bingo!! DVD, DIVX, radio, etc....
Didnt have a chance to take pics last night.... but will try put some up today after work!!!
One quick question..... where's the best place/way to run a power cable for an amp....??? I'm thinking of putting a sub in the back... but couldnt figure out where to run the power cable through the firewall.... any suggestions...?? best/easiest way...??
Follow your accelerator cable towards the front right gaurd to the firewall where you will find
the big rubber boot/grommet, and push that sucka through.
Small hands helpfull here, then pull it though around the footwell area, under the carpet etc....
Or
Go from inside of the car to the upper right of the drivers footwell where you can just see the rubber boot/grommet and accelrator cable come through the firewall and push it through there, wander around to the engine bay side and pull it through. i did it this scond way and used a bit of coat hanger to hook the cable and pull it through enough to reach the battery.
Thought i'd post up a few pics of the final product.
Installing the deck is pretty much same steps as installing a deck and there's threads on it here.
The other pics are of where the screws are to take out the CD Stacker (make sure you gently place it in the bin :D ), and you can see i've half taken out the screws in the pic.
and another pic of where the AV input is for the screen, its in front of the CD stacker and I took a pic underneath of it which shows the RCA inputs.
Hope this helps others as Chooks instructions definitely helped me!!!
Fulock, are you able to play a PAL dvd thru this baby as is?
Yes I can! :(
the paused R34 in my pic above is from Too Fast Too Furiouse - that little 10mins clip at the start before the actuall movie starts....
Last night I was watching a divX disk full of TopGear!! :D
  • 2 months later...
i did the exact same thing today. Wired the headunit's parking brake wire to the earth so that it'll work with handbrake off.
However it seems the car has a sensor that detects when the car is put out of P or N... And turns the screen off when driving and just has a message on the screen (in jap, I assume says something like "screen disabled while vehicle in motion")
Does anyone know how I can make it so I can have the screen on constantly??? It's annoying cause I'm taking the car to Canberra in a few weeks and the DVD's there for my passengers to watch on the drive over and back.
The screen overide is quite complicated, requires a piece of aftermarket equipment, PM sent
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
