mine has a gates and also has the annoying whine
at idle its just an unhealthy sound coming from the front of the engine. quite loud when you have your head in the engine bay. you don't notice it too much when you're actually in the cabin, and never when you're moving
but its never good if you're trying to sell your car and it's making strange noises from the engine...
I'll have my gates belt on by tonight so ill let you'se know wether it makes a lot of noise. I don't understand how a belt can make noise if it is installed correctly......but we shall see.
Does anyone have a Tomei or HKS belt they can vouch for as being a better purchase than the gates or OEM???
Hey off the subject PM-R33 how are those HKS 256/264 camshafts working out for you?
I was thinking of those or maybe poncams but wanted some feedback first?
And which cam gears have you gone for???
I've a GT-RS on board as well and am wanting to get as much out of it as possible.
Cheers.
due to all the blue junk being stuck onto the idler this makes a uneven surface for the belt to run on which inturn makes the noise.
Mines just the normal black one, i didn't get the blue one.
We installed the cams last night and finishing it off today, should be all running tonight and then it gets retuned next week, so i'll let you know what they are like :)
Edited by PM-R33
Ok so we finished putting the timing belt, seals, tensioners, camshafts on last night and started her up. She's having a bit of a problem idling but the retune will fix that. Now the cams sound tuff as f**k for relatively small cams, i think once tuned it will settle down a bit but i love it the way it is :D As for the gates timing belt, it doesn't make a sound at all so not sure what everyone is talking about, maybe its just the blue gates racing belts, i've got the black one. Overall very happy :O
]So how does it drive now? Or are you not fully tuned up yet??????
How's the new torque curve?
I've got it idling now so it drives fine, its not perfect but it is drivable (just jumps around down low a little bit on low throttle or when backing off). Don't really want to give it much until it gets retuned again just incase so ill let you know. I hope the sound doesn't change to much once its tuned, sounds very different.
And how's that GTR A-lsd working out for you?
WHat difference has that made?
Certain model series 2 R33's came with the GTR V-SPEC A-LSD from factory, mine is one of them :) Not sure if it was a factory option or wether it was the last models of the series 2's, cant remember now, read about it on here a long time ago.
Edited by PM-R33
It's an option.
As for Gates belts being noisy etc, not sure what you're all on about but mine is fine and has been all along :)
Ordered a nissan kit with pulleys belt seals and water pump so im sorted! Guys is it worth spending money on an adjustable cam gear for an rb25 making around the 200kw mark? been told by some fairly reptable people that work on rbs that they are not worth it at all?
cheerz
brett
if its noisy making a wiring sound its to tight.. end of story. regardles of brand.
mine only makes the noise if i have the timing belt cover on. i believe it has something to do with the fact that the timing belt must rub on it
    • A few more recent pics
    • full send the cnut, do this   fark the wrapping and/or stick on siet. These guys are the ones to go to: https://www.realthermo.com.au/
    • Just had a look, they don't. Fuelling on the base map is purely alpha-N, and the ignition table is MAP. Remember it's just a base map to get the car moving
    • Hi everyone, I’m Dave from Canberra. Here's a few pics of my 1992 R32 GTST coupe which I imported back in 2006. Only mods so far are HKS Hi-power cat back exhaust, K&N filter, ATC Volanti steering wheel, Pioneer stereo, amp and sub. This was my daily driver up until 2015 and sadly hasn’t been driven at all in the last 5 years due to marriage, work, and kids taking up most of my time and spare cash.As such its in need of a bit of TLC and one of my goals for this year is to get it back to running condition and maybe look into club/historic rego. I’ve joined SAU so I can ask a few questions along the way (although I promise to google Current Problem +SAU beforehand!)
    • From talking to the mx5 guys the NC doesn't actually need bonnet vents like the earlier NA and NB models, due to a better designed cooling system and undertray design There's plenty of them used as street cars and weekend track toys running anywhere from around 170 to 250kw with stock non vented bonnets, I initially was going to get some bonnet vents, but, as they are not actually required, I'll put vents on hold for a while and just monitor temps, though I do need to get something to actually monitor engine oil temps though, coolant temp can be pulled from the OBD2, but the oil gauge in the car is not actual oil temp, it is only a calculation based off coolant temp and RPM ☹️ They do recommend upgrading the radiator, which I have already done with a triple pass, and the only other thing they recommend for a street car is heat management, like I talked about above to protect bits in the engine bay from radiant heat, and to either replace the nearly 20 year old plastic coolant expansion tank, which I have done, or get a aftermarket alloy jobbie for some bling They did also say that if I wanted to track the car on occasion a oil cooler and sump baffle would be required, and as I already have had a sump baffle installed when the engine was out......... I'm going to get a oil cooler with a thermostat....... just in case I do eventually track the car, but probably not, but still maybe...🤪
