Plenty of people recently have heard about Daalder in BoxHill and have headed down there. I met so many people with modded cars down there last weekend. I will be there this weekend.
Basically the system you refer to is the resonator which he claims is his special invention. It tapers in slowly to slightly less than 3" then tapers out again. It is about a foot or so long with stainless steel wool wrapping.
I don't believe it will reduce all exhaust to 90db as the muffler comes into play, but basically if you fit it and epa with them they should pass you... afterall it is their "invention"
If you ever have any probs, go back to them, they are a great bunch of guys. I chatted with them for hours.
Pushead is using their resonator.. he luvs it.
https://www.sau.com.au/forums/topic/21990-daalder-exhaust/#findComment-469019
Everyone, if you got to Daalder in Box Hill, tell Matt that i sent ya and you're from the Skyline Club (I'm Marcus - i'm the one with the 108dB silver sky). He should look after you in terms of $$.
BTW he is really proud of the silencer - just ask Pushead! :P
https://www.sau.com.au/forums/topic/21990-daalder-exhaust/#findComment-473604
    • Ok interesting i guess ill wait till using a manual gauge before making assumptions.
    • Not in any way a logical conclusion. Also, looking at those logs, I struggle to see how that much oil pressure can go away that fast unless you are sucking air into the pickup. Meanwhile the ECU voltage is chucking a huge wobbly which seems to be tied to the throttle position. 100% throttle results in decreasing voltage. It's a mess.
    • So didn't get around to installing a manual oil pressure gauge and then decided to take the car for a cruisey drive to a cars and coffee and brought the laptop along with to get another log using more gears to see if its an oil pressure issue under acceleration or after. this log has 3 gears of WOT where as previous had 2 and the oil pressure dropped once on the brakes, and the same again happens here which is interesting as it shows it can hold oil pressure while under acceleration but once slowing or just the lower RPM after a pull pressure drops. I will be chucking a manual oil pressure gauge on to confirm but so far this makes me feel it is not an electrical issue. Something else i realised is the pressure sensor also is giving temperature information and the temp stays steady the whole time which makes me feel like the sensor itself is showing a true pressure reading.
    • LOL.... fk...   there goes 25K to make 200kW
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
