TRUST =
Was just gonna post that :rofl:
That was with a BatMBL split dump, 3" catco, and trust pe II. It sounds a little different under load than in my garage there. It's a pretty quiet exhaust until you give it some.
are u serious? u must be talkn about some diff type of kakimoto because the only ones on sale atm are the mega n1 and the Regu 06 & R. and both are 3.5" exhausts with a 6 or 7" tip. that thing is a monster.
Yeah that is what I was thinking... I mean the Regu could possibly be a bit quieter but the N1 full mega is a beast... But still compliant, which is what I'm looking for...
yeh i agree, trust are very quiet. have u ever tested it with a db metre?
I know this is an R33 GTR, but here is a sample of a Kakimoto zorst..
which kaki is the importent question. if itsa 6 year old exhaust theres not much point in lookn at it. just like the old HKS dragger systems
Edited by R34NRG
There are so many different opinions on all of the mentioned exhausts and its hard to tell from youtube vids because there are so many different variables that all the cars have that which change the exhaust note. I haven't shopped around too much yet, but from what I've seen not many of the exhausts have a kit available for 4 door 34's which limits my choices a bit. To summarize what has been discussed so far...
Trust PE2 - a little bit too quite for people's liking
HKS Silent - not too quiet, not a bad note when your pinning it
Kakimoto - N1 sounds like a monster with a 6" or 7" tip - so probably bit too loud for what I'm looking for
Blitz Nur -sounds pretty sweet, but i dont know if it comes with a 4 door kit
Apexi - does it come with a 4 door kit?
HKS HI-Power - ?? not sure any thoughts
I haven't tested it with a spl metre.. but in comparison to my previous systems - Nismo, Apexi N1. It's louder than the nismo, but still far quieter than the Apexi N1 (i found the N1 a little too barky for my tastes, whereas the PE2 has a much deeper note to it).
i still rkn HKS silent sounds like a girl......dosnt have that note i like.
the HKS Hi POwer is another story, very very nice exhaust BUT is in mild steel which we all know isnt that great compared to stainless.
Yeah well my other mate has the kakimoto exhaust with the titanium tip look one, and gosh its even quieter than the HKS silent one and really can only hear it if your right behind the car.
that would be the Regu 06 & R.
gosh maybe im wrong....i always heared those things were monsters.....full turbo back system ur mates? 3.5 all the way?
I can vouch for the batmbl / Bos importing and Catco metal cat, they are great. I have them on my R34 GT-t 4 door.
I have some Nismo cat back system, but i cant comment on the sound it makes. When i was putting on the dump pipe i snapped a bolt in the turbo, and ever since all i can hear is this huge exhaust leak sound haha.
Blitz Nur Spec V exhaust, not the spec R. In terms of performance it's one of the straightest systems out. And the note it makes is bloody amazing. I haven't heard another exhaust system on an rb make such a sweet note... 900 bucks catback system. All you need then is a hi-flow cat and your front/dump and your done. I reckon you could get away with it for about 1200 if you fit it yourself.
Good luck,
Ev.
ive got a blitz nur spec 3" catback and cat from batmbl im planning to get rid of for a 3.5" system
anyone interested shoot us a PM.
but ill try get you some youtube vids asap.
honestly i still rekon the Blitz sounds the best. but unfortunately for me its a 3" system and not a 3.5 or a 4 =[
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
