Hi everyone from Russia :D couldn't find any info on the following topics here (Russia), so decided to ask you ;)
i ordered HKS Head gasket 1.6mm - are there any difficulties to install it? or i can just replace it and increase boost and fuel?
what are the best A/F ratio for 8.6 Compresion level? and what is the maximum boost that it can handel?
Will RB26DETT camshafts fit into RB25DET?
I'm also looking for close ratio gearbox - but cannot find anything.. only for RB26DETT and at about $5k cost :(
are there any substitudes for this?
thanks!
close ratio gear boxes start @ 5k
with the head gasket 1.4 bar should be ok jsut watch out for detonation as for a/f ratio's aim dfor 11.8-12 to 1 to be safe you will make more power going leaner but this is safe
rb26 camshaft will fit but you will ahve to convert from hydrolic lifters to solid to run them adn you would loose your vvt.
my site has head torqing specs on the parts and info page
cheers
meggala
btw great english
to say the truth, i didn't understand anything what is written about head torqing specs :( what's that?
what if i get HKS camshafts IN and EX lifting 8.8 and 9.0 - will i have to get rid of NVCS system?
i also order S-AFC II, do you have any maps for it already? or i should configure it specially for my engine trying to be in 11.8-12 to 1 a/f ratio?
btw, right now my boost is about 0.5 - 0.6 (max), if i make it higher there is some kind of blows out of muffler and engine stops to rev for short period of time (milliseconds), and that affects the acceleration.. i thought that there are some kind of fuel limiter and order fuel cut defenecer - will this help to solve the problem?
also, will the standart turbo give boost at about 1.0-1.2 bar?
Originally posted by S14Drift!
Everyone say that the max boost for stock turbo is ~ 15 psi or ~1 Bar ..after that your pushing too much for the ceramic turbo wheel...and it will destroy itself!
Not sure where u read that? Most people from what I have read say that 12psi is the most a stock RB25DET Turbo should push. I wouldn't be all that game to try anything higher really.
benm, I'm running 14.7 psi and it probably spikes a little higher than that at the moment. No problems at all (so far... :P)
I do have a series 1, though, and the general consensus is that they can take a little more boost than your series 2 R33.
I have a '95 S1 R33.
Im abit scared of the whole 'boost' thing.
To me the higher the number = the higher the danger which is probably why i drive around on 7psi all day everyday :P
On 12psi im leaning out so no point in winding it up any higher. How long have u been running 14.7psi for? Also how long do you run it on full boost for?
I wonder what gains i'd get and how long the turbo would last.. (provided th rest of my car is working fine.
Well it's been that way for over 6 months now and I do give it a little bit every day. I've also done a fair few 1/4 runs at my private dragstrip. It felt stronger than 12 psi, so I left it there).
Also, I'm not really a big believer in high/low boost switchable setups, cos I like the idea of having the car run exactly as it was on the dyno. So that's why I only run 1 Bar. That said, I've seen a unichip setup where the guy had different maps for high and low boost and also for shit petrol. It was really good. I almost bought one when I saw it.
My car was nowhere near leaning out when I upped the boost. In fact, before I got my SAFC I had A/F ratios in the 9s! Then again, you have probably got one of these magical 95 ECUs.
I believe I do have 1 of the magical ECU's coz I currently dont have any aftermarket management of anything.
The only time I use 12psi is for Dyno runs, Trackdays and eventually 1/4's.
Guest INASNT
please dont make this another thread about what the max psi u can run the stock turbo at!! We have had a million of em already, if u r game run it higher and higher and then when it blows u will know the limits!!
Vovan
As the the hks 1.6mm head gasket, thats a good buy, but u should get some cams and head work done if u r gonna replace the head as u will have all of it out anyway.
The S-AFC doesn't come with any settings pre-set. You may be able to apply someone else's map if they have a similar engine setup to you, or do it on the street yourself, but the best way will be to do it on a dyno with the proper AFR monitoring.
the problem is that we don't have any dynos here :D(( first i ordered camshafts but then decided to cancel that order cause no one will be able to configure them properly here :D shit country :)
Do you guys have any tips how to configure S-AFC without any hardware... it won't show A/F ratio, will it? :( how can i know if the mixture is rich or not?
now i'm thinking i should by PowerFC instead of S-AFC and AVC-R and all the limiter's removers... :)
BTW, is it possible to remove the rev limit and move it, let say, to 8k instead of 7k? will it help? i didn't find any info on that here in the forum.
Guest INASNT
there has 2 be a dyno somewhere there!!
u wont know what a/f ratios u r running unless u get an oxygen sensor of some kind and place it at the end of your exhaust.
u can move the redline to 8k with a pfc
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
    • Pretty sure they run the same engine as the Q50 hybrid which specifies 95 RON.  I ran 98 in mine for a while, but it made no difference in performance or economy, so I have been using 95 for the last few years.  I have never hit 6.0L/100km, but have returned mid to high 6 on the highway.  Being a hybrid, fuel economy is a lot more dependant on how you drive it.  At 110km/h, mine never goes into EV mode on the highway, so returns closer to 7.5L/100. urban driving can return low 8s if you are careful or over 10 if you are a bit more enthusiastic on the throttle.
    • About a quarter of what you want to do. It's only R7R, not R&dismantle&replaceparts&reassemble&R. ? It is stock. I already told you, you will NOT have broken those. It's f**king 4th gear for Christ's sake. You just chipped the teeth off.
