Hi Guys,
Okay here it goes, i installed a new dash cluster only to find that the previous owner had disconnected the Air Bag light.
When i installed the new cluster the Air Bag light would flash on and off repeatedly.
Now since i am 99% certain that there was no accident history i began to wonder why this could happen?? Well i think i have the answer afer some searching.. :D
Click here
It seems as though the way to fix this is to reset the Air Bag ECU, very strange procedure:
You can get rid of it by...
Flashing ABS light reset
Key on door open
Key off
Key on
Hit the door pin switch 10 times
Will only work if light is flashing
Can someone explain this process in more detail please? what does each step mean?
Im sure this will be of help to other fellow S2 GTR Drivers some day!
Thanks,
Harry
Edited by GTR-PWR
  • 3 weeks later...
best way is to check the fault with a scan tool
so you know what part of the SRS system is causing the control module to log a fault
but the steps you have listed above go like this
enter the car and close the door
turn the ignition on
open the drivers door and leave open
turn the ignition off
press the door pin 10 times (located on the bottom of the B pillar)
now when you turn on the ignition back on the SRS light should come on for 10 seconds and then turn off and stay off
ive got the same problem but mine is constantly on.
when i bought it, the previous owner told me he removed the steering wheel to boss kit on, only to realise theres a different boss kit for air-bagged equipped steering wheels...and its a defect, so he put the original wheel back on and ever since the light is always on
ive tried the above procedure, but no luck (prob. coz my light isnt flashing)
any help guys??
  • 4 weeks later...
any help guys??
any luck finding a solution?
my 33's had the airbag light on since i purchased the thing. it has had the standard wheel replaced with a momo wheel and boss kit. i've just purchased another airbag wheel but am hesitant to fit it incase there's a fault in the system which may sett the airbag off in my face and ruin my new wheel.
i cant be sure that the light is only on becase of the non standard wheel and not because of an accident which may have occured before i purchased the car.
any help????
if you fit it all up and the ignition is off it wont go off
and even if there is a fault logged it wont fire the bag
fit the wheel and airbag, turn on the ignition (make sure your out of the car) check to see if the light is still on
if it is
follow the above procedure
  • 1 month later...
Just tried that and it worked for me!
    • Just don't use ChatGPT or any other artificial stupidity for the equivalent of googling. Their demonstrated inability to discriminate reality from hallucination should be enough to make them totally untrusted. LLMs don't know anything and cannot think to even the smallest extent. They are just predictors of the next word, and that should never be confused with capability.
    • I think, given the usage model described in the OP, I'd never ever experience the wonders of the 400kW upgrade. What I really need is boost from 2000rpm and probably no more than 260-270rwkW. But I suspect that the highflow is not actually the turbo for that purpose, so I may in fact need to get a G25 or 30 or something right sized and very spooly. We shall see after it is tuned. I've had to back the boost and boost ramp off to stop the thing from pinging since the highflow went on, so I've been almost living the NA life for 9 months now! Injectors are recently in hand. AFM is in hand. Dyno is fixed. Just need to clear a queue of f**king Supras out of the way (and probably fit my new gearbox). So....some time this year? Lol.
    • For what I gather is a Sunday/summer car....braided is fine. You're not going to be left without a vehicle and you have plenty of time for inspection/maintenance. Oof. I wouldn't use them that way. They can probably handle the temperature** but the internal corrugations means that their flow characteristics are a bit shit. Lots of extra friction and pressure loss. Makes them flow like the next pipe size down. ** They are stainless, and the stainless can usually be at least something like 304L, which is pretty good at higher temperatures (unlike 316L, which I would use for a wrt/corrosive environment, but not a particularly hot environment). But the welding needs to be top notch. And even then, because you usually need at least one cone-seat end on them (because you can twist the hose and do up both ends at the same time unless one of them is a union) they can be prone to coming loose with heat cycles.
    • I don't have the OEM oil feed lines though and the turbo-wraparound line is torn, only has water. My plan is to get replacements for these and just connect a braided line to there. And make sure it's leak free. Hoses like these are also sometimes used to connect external wastegates, so for an EGR I think you're good using them.
    • Alright I understand. The most likely case is probably gonna be that I just keep the OEM unit in the car as long as it works.
