  Munkyb0y said:
What is it?
Is it wired to the bonnet release pin that you can see in the bottom right of the photo.
It may be the wire that sets the alarm off when the bonnet is lifted and alarm is armed.
no, not the wire that goes to the bonnet pin. i'm asking about the black puck shaped thing with the plug and coloured wiring. its mounted to that steel bracket, just behind the pod.
Edited by Munkyb0y
That's not in my R33, thats for sure :)
I've helped a friend put a pod on his R33 too, and he definately doesn't have one either. I don't think I'm remembering incorrectly, but I don't recognise it at all
no its not rubber. its hard plastic.
here are some clearer pics.
the green line follows the wiring as it comes in through the guard and goes via the plug, directly into the top of the 'puck'.
there are no other wires coming in our out of the 'puck'.
the dotted line shows where it turns inside the guard, and heads rear-wards. i can follow it under the guard for about 200mm, before its hidden behind the inner guard.
the plug looks like the standard nissan plug, ie same type as the boost solenoid, so i thought it was something standard.
Edited by Munkyb0y
i dont think its that.
there's only one set of wires going in, and nothing out. why would the harness lead to the engine bay, and do nothing once it gets there? strange.
could this have anything to do with the blinkers?
heres a shot of the under side.
it had a shitty alarm when i bought it. may have been a rhino. but i got a decent one installed.
as far as a dealer fitted alarm, not as far as i know.
what kind of pics do you need? thats pretty much every angle of it.
the writing on the top says PSC-22 3X0
Edited by Munkyb0y
  R34GTFOUR said:
what happens when you disconnect the plug?
also what series is your 33?
its very odd
good question. i havent disconnected it yet. i wanted to know what it was first. i had no idea it would be anything out of the ordinary. i will try it tomorrow.
i will also try to trace that wiring and see where it leads.
its a '93, series 1.
could it have anything to do with the ecu? its a unichip with boost controller module attached. but as far as i know, that only consists of two pieces which are both behind the kickpanel.
Edited by Munkyb0y
^ thanks mate. i'm still not sure what it is.
here are some more pics.
this is the path it takes into the cabin, behind the glove box.
there is a constant 12v at the red wire.
notice how its wrapped in the protective foam, as if it were factory fitted? confusing, because those joiners dont look factory :)
some close-ups of the mystery unit.
post-29392-1211790568_thumb.jpg post-29392-1211790587_thumb.jpg post-29392-1211790600_thumb.jpg
Edited by Munkyb0y
