  Quote
-Stereo/dash plastic surround with clock, power window switch and coin pouch $100
Hey mate, does that actually include the d/s power window switch, or did you mean the power mirror control thing? At any rate I'll take the window switch off your hands if you still have it :ermm:
  • 3 weeks later...
ignition barrel n key?
price?
  NSPM said:
Hello,
I have been wrecking a black R33, so I have a heap of parts for sale. All prices are negotiable and postage is extra. I am in Sydney and condition of all parts is very good – excellent unless otherwise stated. These are all the parts for sale listed here. I will however, be making additions in the near future. I can take pics upon request, please ask if you want them and PM if you want any parts, as I probably won’t check this post heaps often. :woot:
-Brake booster (non-ABS) $80
-Accelerator cable $30
-Radiator over flow tank/reservoir $20
-Steering column with ignition barrel and indicator stalks $60
-Series 1 steering wheel $40
-Hand brake and cable $100
-Boot release cable $20
-Fuel pump on bracket $40
-Fuel level sender $20
-Electric aerial $20
-Boot lock $20-missing badge
-Rear wiper motor and rear wiper $50
-Front wipers and motor $20 each
-W/screen washer reservoir with both motors $50
-Heater hoses $50
-Brake and accelerator pedals $30
-Power steering reservoir and hoses $50
-Rubber door seals $80
-All interior trim (series1) $250
-Moulded carpet (standard and worn on drivers side) $100
-Rear seatbelts $20 each
-Centre console – damaged (lid still works) $30
-Glove box $50
-Single din cd player and pouch shelf with stereo brackets $50
-Dash instrument cluster surround $20
-Dash vents $20
-Steering column and indictor two piece cover $20
-d/s under dash trim with fuse box cover $20
-Central locking computer $20
-Under dash fuse and relay box $50
-Interior door sill garnish – d/s and p/s $40 for both
-Sun visors $40 for both
-Rear view mirror $20
-Interior light $40
-Sunroof with switches and motor $200
-Rear shelf with 6 inch speaker holes $20
-Hicas computer $30
-Jack bracket $10
-Battery bracket $20
-Standard earth cable $5
-Side Skirts D/S$70 P/S$20-(damaged)
-Rear pods/skirts $120
-Exterior B-pillar trim/covers $50 for both
-Exterior door mirrors complete with motors $70 each
-D/s door with glass and all mechanisms $250
-P/s central door locking mechanism and lock $20
-W/screen water spray nozzle jets $20 for both
-Upper firewall cover – under w/screen wipers $20
-D/s front fender $150
  • 3 weeks later...
  • 3 weeks later...
  • 4 weeks later...
Hey guys,
sorry its been a while. I have no internet connection any more, so if possible could you please contact me via sms or phone call if you have any queries as i won't be able to check this often,
Thanks,
Adam 0405326007
  • 1 month later...
    • Even with the piston at TDC there was room for it to drop, but I don't think it can drop fully into the cylinder, the problem you have is that you need something pushing against the valve to hold it up so you have enough room to put the new stem seal on and the spring etc.  I used compressed air only because putting rope in the cylinder seemed a bit risky to me, I know people have done it countless times before like this. Overall it's a pain in the ass job. Honestly you'd probably be better off taking the head off because the risk of dropping something in the engine and the finicky-ness of it all is very stressful. If you are going to attempt it though i 10000% recommend a 36050 valve spring/keeper tool. I had both the traditional lever type and after doing 1 cylinder it was absolute pain to get those valve keepers in place, even with 2 people. That 36050 is amazing, you do have to push hard to get them in place but it works perfectly almost every time. Back to my actual issue I think my engine is just tired and old and the rings have gone bad. The comp numbers (cold, no oil) were: Cyl 1 -129psi Cyl 2 - 133psi Cyl 3 - 138psi Cyl 4 - 137psi Cyl 5 - 157psi Cyl 6 - 142psi   Cylinder 5 and 6 having the most carbon on them.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
