Hi guys...
Well after work i was driving for a bit about to take my GF home / see a mate and yeh. Roads were wet and slippery, was on a hill turning from a road (going down the hill) right onto a road (still on a slope) was doing about 40k's slowed down like usual, prob entering the corner at a MAX of 15k's and then felt a bit of understeer, so i figured yeh took it a little bit fast just brake a little and fix it up like normal (obiously i have experienced understeer/oversteer before and know how to correct it) but this thing just wouldn't correct, it was like i was on ice and kept sliding, went into a gutter (front left) and it just kept going a little further and i hit a tree (front left), took a little while for me to realize what had happened (shock i guess) hardly felt anything in the car.
And yeah organized a tow truck and the usual.. I have full comp with Just Car and just sharing the shit night it just became, and wondering what you guys think will happen from here?
So disappointed in myself.
Leigh
https://www.sau.com.au/forums/topic/219993-had-a-incident-tonight/
  • Replies 59
Posted Images
Damn man, that really sux!!!!!!
Sometimes roads turn to ice and there's just no stopping, no matter how slow you are......
really suck cos I know JC has really high excess!>...
Depending on what needs repairs, might be better not making a claim and just paying for the repairs. It might affect No claim bonus or increase you premium for a while.
just things to consider before finalising the claim..
more than 4-5k for a good repair to that IMO. Lots of stuff will be pushed in that you cant see :)
I'd take it down to Micolour for the repairs as it'll be done right the first time :)
Dont feel too bad over it mate, sh|t happens. On a cold/wet night there could have been some chemical/ice etc on the road and thats just how it goes sometimes.
Cause might have been tyres? I know in these conditions of the season tyres that might not be upto scratch might be a cause, just something to look at.
Least your alive and ok, thats the main thing, let insurance do the rest :)
over a tonne of moving mass at 15klm and a whack right on the rad support/upper skirt would do that kind of damage no worries....youve got to remember that the force is more concentrated due to the diametre of the object he has hit....example if he hit something that was 2 metres wide there would be less damage due to the load area spread across the wider object
Oh well lucky you are not hurt.
I had a similar incident in my old car, but didn;t hit anything thank christ. As Ash said probably the tyres, mine were fine in the dry but a death trap in the wet, particularly if you has stiff suspension.
Good luck with the repairs!
thanks for your expert opinion. we can tell you studied hard :P
Physics yea??? or was it back yard testing lol
Yeah it sucks :P making a claim today, and yeh see what happens from there i guess.
The road was on quite a steep hill going down, then right if that makes sense.
Honestly i wasn't screwing around or anything like some of you may think.
I was so shocked at what happened I really didn't expect anything like that, be careful in the wet and frosty guys don't want to see this happening to more Skylines throughout winter especially.
    • Next pic will probably bring back Charlie's PTSD So yes, pump is back out. I hooked the fuel return up to a hose into a container to flush out the first litre or 2, jumped the Fuel Pump relay and.......nothing.... Turns out the pump I had pulled out, checked, cleaned everything....was dead.  I hadn't actually hooked 12v to it to check it worked before I put it back in. Anyway...Neil had kept the old pump which still worked, so I just swapped it back in. All good, flushed the lines out, ready to start
    • OK....so something that works like it said on the tin! Fitting the pressure feed into the car was an absolute PITA because the oil filter is in the standard location and then there is a fitting to run to the oil cooler. On the other side between the filter and the steering box is the standard oil pressure sender (not working for some reason, something to check) and 2 tapped 1/8 BSP threads for the oil temp and pressure gauges. Unfortunately it is really tight in there and it took a hours of stuffing around to get a t fitting to connect the priming pump and retain the gauge sender.  Also, the Aeroflow sump has some massive drain plug (needs a 32mm spanner) so I couldn't use the regular fitting there either. In any case....once it was all hooked up, like magic priming.mp4 15 sec, 3 bar of oil pressure. Left it running a couple of minutes to push through everything, looked good
    • Yeah the latest style kit has been trouble free, I've done a fair few klm on it including pushing a bit on low fuel and it hasn't been surging (that's not an endorsement for race use, I haven't tried that low, or that hard cornering!). For street use it has been a good thing, handles the high current OK, only real issue is it is not cheap
    • So, how do you feel about the Frenchys surge tank setup @Duncan? Have you had a chance to try it out more? The sketchy wiring in my fuel pump setup has decided to melt and die and I'm looking for a solid replacement now. My fuel hat is toast so the Frenchys kits providing it all look promising.
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
