That'd be the accident on Kent Ave, Croydon? I remember that, it was absolutely tragic :( Terrible piece of road in the wet, it was only a matter of time before it happened.
To the thread starter - sorry to hear about your accident but good to hear you're comprehensively insured. It does look like a fair amount of damage.
yes it was.. fortunately the passenger, another mate of mine survived. yes that blind corner is pretty bad. i was at the pole putting flowers up a few days later and while at the pole could just tell by the way cars were taking that bend that it isnt the best stretch to go down.
i now drive like an old grandpa in the wet :bunny:
please take care on the wet roads guys ;)
  • Replies 59
Posted Images
Thats if it isn't a write off, in a way it would be better to be.
edit: So you n Matt taking me and my gf to midnight cruise or what? :woot:
ahaha nah man, i aint going to the midnight cruise - 5 hours is too long for a drive for me.....
Well i got called up today by just car (they have been really helpful btw) and they told me the car is a write off and the accessor will call me tomorrow to organize payments and stuff i guess.
Written off...geez, If that was an old Valiant or similar you'd get out the black texta, write "ouch" on it and keep driving. Damn mono-coque chassis/shells, they save weight but the can't take a 15kph tap.
Don't forget....quality tyres before anything else, no point in having a nice car that won't turn in wet/greasy conditions.
get a r34 4 door. sorry to hear man. driving in the rain can be scary.the thing i always do is if the road has a overtaking lane go into that because the water runs off them so the right lane will be better with no puddles and a safer drive. thank god i have good tyres i have pirellis (i think thats how you spell it). at least your fine thats the main thing cause cars can be replaced and people cant.
Dude that sucks, hope you get is sorted soon.
My R34 GTR was written off coz some scum people broke into it and damaged it beyond belief
-Brad
Geez! That's exactly what I'm scared of. For a 34 GTR to be a write-off.... they must have done like 60k damage without even starting the engine. What did they do? Burn it?
    • Quick update.  The engine grounding strap was replaced, the engine is now happily running.  Tested the voltage drop before replacing the strap, was about 1.2ish volts down between engine to battery, chassis to battery. With the new grounding strap, pretty much no voltage drop at all.
    • I was chatting with an ex SAU person who is involved in chooning euros now. He was saying the factory cars like Audi VW etc have something like 2000 tables that the ECU uses for getting everything "just right". Compare that back to any aftermarket ECU, and you'd be hard pressed to surpass 50 lookup tables. Even the Ford Barra engine has a few hundred lookup tables to run it (and they're still working some tables out too!)
    • Grab a temp probe, and probe each exhaust inlet runner with it sitting idling. Each one should be pretty darn close to the same temp. If you've got some reading higher or lower than the others, it's likely either air flow isn't equal, or your injectors aren't equal to each other.   The other things to check, is from the wiring changes that were made, were any earth's or grounds moved/changed.   Lastly, for the strut brace issue. It's not perfect, but can you get away with slipping a washer or two under the strut brace to raise it, and it still clean the bonnet? If you can, work out the height you need, that the motor can't torque up into, and get a spacer made for each side.
    • That rusty R32 fuel tank is what we found in Clinton's R32. It has since been replaced with a R32 GTR tank and all it took was a bit of ingenuity in building new fuel tank hangers. I cannot believe how simple the R32 fuel level sender is compared to the R33 unit.
