Now Accepting Orders! Ati Super Dampers (harmonic Balancers) Gtr R32 R33 R34's,
Hey Guys,
Looking for anyone interested in buying ATI balancers. I need to know how many people are intrested for the following part numbers before I can give you a firm price. The more people we have the better price we get, pricing brackets start at 2, 4, 8 each part number.
Nissan Skyline GTR RB26DETT R32 R33 R34 ATI super Super Damper Harmonic Dampers
918599 - STREET: R32, P/S, A/C, Alt Up to 500HP All Pulleys are in OEM locations. Power steering pulley is 15% underdrive, alternator and water pump are 5% underdrive. A 10mm shorter belt is required for power steering pulley. Damper shell and pulley are aluminum with steel hub. Be sure to check your crankshaft for roundness. If it is equal to or more than .001" out of round, you will need to adjust for proper damper press fit.
917752 - STREET:R32, P/S, Air, Alt, 600–1000HP Damper includes new aluminum water pump pulley for clearance. A/C belt is a 25% overdrive - DO NOT USE BELT IF RACING! 15% underdrive on power steering, OEM size on water pump.
918598 - STREET: R33 & R34, P/S, A/C, Alt Up to 500HP All Pulleys are in OEM locations. Power steering pulley is 15% underdrive, alternator and water pump are 5% underdrive. A 10mm shorter belt is required for power steering pulley. Damper shell and pulley are aluminum with steel hub. Be sure to check your crankshaft for roundness. If it is equal to or more than .001" out of round, you will need to adjust for proper damper press fit.
917753 - STREET: R33 & R34 P/S, A/C, Alt, 600–1000HP Damper includes new aluminum water pump pulley for clearance. A/C belt is a 25% overdrive - DO NOT USE BELT IF RACING! 15% underdrive on power steering, OEM size on water pump.
Who's Interested?
1,
2,
1, italiasr
2,
1, YO88O
2,
1, Jz-r33
2, angus_smart
3, ommuru
Post up here if your keen.
http://www.atiperformanceproducts.com/prod...s/damnissan.htm for detailed info.
Cheers,
Johno
  • Replies 115
Posted Images
if your price is around right i'll be in for a
34gtr 600-1000hp. i guess n1's @ 1.7 bar should net me over 600hp.
917753
i was considering doing this myself. but one group buy at a time is enough
Edited by Angus Smart
That would be right. I just ordered mine.... got it in the post last Monday, yet to be fitted. Oh well! It looks nice though :D
Thanks guys, getting a much better responce then I thought.
From first round negs. the pricing is as follows. I am working on better pricing from a few venders in the states. Due to the quantities we require im confident we will get a much better price.
Price excluded shipping and is in US$
$450.00 1-2
$400.00 3+
$520.00 1-2
$500.00 3+
918598 - R33 & R34, P/S, A/C, Alt Up to 500HP
$470.00 1-2
$400.00 3+
TBA
Cheers
Johno
The 918598 one is US$419 at summit too
Do you have a link mate? keen to talk to these guys.. cheers Johno
EDIT: sorry mate didnt hit refresh quick enough.. thanks
Ok, I will get summit racing involved in the process.
[200] - which one are you interested in mate?
T04 GTR - I will ask the suppliers for pricing on all belts to suit the balancers.
Sorry I cant edit my first post for some reason.. below is an update on the people interested.
1,
2,
1, italiasr
2, Adriano
1, YO88O
2,
1, Jz-r33
2, angus_smart
3, ommuru
4, Ali-Turko
5, T04GTR
6, T04GTR
7, T04GTR
8, Smoky
Guest
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
