i have a r33 running a rb25det, just had a 100km service done, and noticed that i have been burnin a s++t load of oil as in drove 1500 km and she was showing low, im using castrol 10w60, i have noticed too that she dosnt idle very nice, well didnt i got the turbo intake looked at and clean there was oil now run a bit better, so im thinking turbo gasket or rings.
hopefully that made some sense, i would really like some ideas on what be wrong and how to check it, coz i dont like my patch of sticking oil in every so often, i have 700km before i have done my first 5000km so going to do filtre and oil, reccomendations
cheers alex :P
https://www.sau.com.au/forums/topic/220021-burning-heaps-of-oil/
I have a similar problem - been suggested that valve stem seals might need replacing.
Valve stem seals will only cause smoke on initial start up...reason being they are a little rubber cup that stops oil running down your valve stem into the cylinder head while the engine is static...when parked over night or any lenghty period the oil will slowly drip down the valve stems depositing a little puddle in the cylinder....start it up and poof, but it burns off quick. When your engine is running the positive pressure from compression stops most of it and it's such a small amount of oil you wouldn't notice it in normal driving conditions or even be enough to notice on the dipstick over a 5000k service period.
The old "my mechanic say it's only the valve seals" is a very old/dodgy way to sell a dud to someone who sadly doesn't know their ass from their elbow mechanically..
cheers alex :thumbsup:
Pull your plugs out and check for oil... The rough idle could be from one or more plugs oiling up...do a compression test, just a guess but I's say #6 maybe oily and a little down.
i have the same problem to
i did i compression test at a workshop and my 5th piston was down 50% to the factory settings.
so i brought a new bottom end with 40,000km on it and it looks like im going to have fun :thumbsup:
yeh agreed with the people saying check your plugs to see how blackened they are then a compression test if they are fairly black.
cheers, Andrew
if you dont mind me asking how much for the bottom and the install, sounds like a lot of $$$$, makes me not smile, hmmmm,
so i brought a new bottom end with 40,000km on it and it looks like im going to have fun :teehee:
cheers, Andrew
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
