I just noticed a similar thread on the 300ZX forums with the idea of organising a group buy.
Although the jack which I consider the best (OME29023) cannot be bought locally, if there is enough interest we may be able to get them shipped.
Yes it does bring up the question about not meeting AS standards, keep in mind that Australia standards must support 3 times the rated limit, thus making it very hard to get approval.
  • Replies 158
Posted Images
See wot u can do :down: im sure i could get a few off the 300zx forums to make up some numbers :down:
Not sure what you want me to do? I'm keen to either keep looking or go with the imported omega but it depends on numbers.
maybe the omega or that AC low profile jack i put a link to is the go. The exchange rates are favorable at the moment to get one from the US.
I'll buy one that is low enough to reach under the front cross member....
I finally bought myself a new jack on the weekend, way too many years using a K-Mart $10 special.
It cost me $260 (normally $299 but I bought $1300 worth of stuff) from GasWeld and is 16.1kg. It is not super low and doesnt have 1 of those little quck pump levers but it does fit everywhere I need it to and is a million times better than what I had before.
Yes it is 1200kg (since when do you lift an entire car from a jack, usually its front or back only then place stands under it immediately).
90mm lowered
450mm raised.
On my standard wheel/suspension r32 gtr it wont fit under the front lip because the base of the handle wont slide under but if I roll the car up onto a 25mm block of timber its totally fine.
As I said their is certainly better out there (maybe more than $299 though) however in the end it only cost me about $150 so im very happy.
90mm lowered
450mm raised.
$150! i'll take one too please!
No worries, go and buy $1300 worth of stuff and haggle a 10% discount as I did, then claim it as a business expense (which it is for me) and the $300 shelf price suddenly drops to a more attractive price.
:D
if i was a tradie then i would and could. a crappy desk job prevents me from doing so............
any other ideas? :D
Its a good jack but just keep an eye on the castor wheel bearings ( and hold on to the receipt ). Have seen 2 bearing failures with this jack. Maybe ( hopefully ) this is a newer/better version than the ones I've seen.
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
