I've got the Bluepoint super low floor jack like the one pictured above...
Definitely a great jack, abeit fkn heavy!
Only dissapointing feature is the reach not being longer... I need one of these to reach my cross member on the 180sx :)
Although having said that... Still can't do much about it as my car is pretty low. I don't think any other jack would do a better job than the Bluepoint one. Reaches the diff no dramas...
My Bluepoint jack + Astro Products ramps = Win :down: No ghetto spec wooden blocks for me lol
PSI Part (Shane): Can you still get those rubber pads for the jacking points still pictured in one of the previous pages? The Bluepoint jack doesn't come with one so I went to Clark Rubber to made one. It's effective, but would much rather the proper stuff as per the one you posted previously...
Cheers,
Andy
sanp on sell them seperately i was advised - need to make a call to get one for mine also - probably get a spare foam protector for the handle too
  • 1 year later...
  • Replies 158
Posted Images
Looks a little like the "Big Red" jack that I bought a couple years ago. Also aluminium, dual pump, rated to 1500kg...
They're good enough, I still need ramps to get under the car, and the only problem is the jack is not long enough to get to some parts of the car.
It's a lot better than a normal jack, and that's a very good price!
thats a costco jack. I bought one from costco for 160 a couple of months ago.
  • 3 weeks later...
anyone know if they have stock atm in docklands vic?
Nil stock at the moment but there are over 500 units awaiting customs inspection, should be in by next week.
I got a full refund on my one after 11 months of hammering, not bad.
I've had a Costco jack fail after only a few months, may have been abused when I lent it out. Costco replaced it no questions asked because there was a recall a few months ago because the jack didn't have the correct aussie standards sticker which mentions not relying on jack alone when working under vehicle.
I have had another friend who bought one when they opened and its still working fine and has had cars raised in the air for months at a time with no issues.
I would still they are excellent value for $160
I was there last week, there was plenty of stock but they had moved from their regular spot, there seemed to be quite a few left, however there are a few people who buy a pallet load at a time and flogs them off to panel/workshops for $250 making a tidy profit.
  • 4 years later...
Bump the shit out of an old thread.
I've been using a 3t SCA jacks for years now and its done the job for the 4b and s13's just fine, but then again i don't have them low.
Short story is, i lowered the track one and now i cant fit my jack in (something like 11cm min on this jack)
Couple of my mates have the Bluepoint ones and ive allways wanted one.
Just called our Snapon dealer and he has a couple in stock and he said they are around $560.
thats for the "Blue Point Long Reach Super Low Service Jack -- SNX1LLTJ "
So given this thread is super old now, whats everyone else using.....or shall i just get the bluepoint and be happy?
My cheapo SCA crapped itself too so I went to Big Red Jacks in Tullamarine to have a look at their stock.
I ended up buying a Torin T815005L 1.5 ton Aluminum Racing Jack, I think it was $150 from memory.
Details: http://www.bigredjackste.com.au/index.php?route=product/product&path=25_205&product_id=272
Before you buy read the reviews, they're a bit mixed: http://www.amazon.com/Torin-T815005L-Aluminum-Racing-Jack/dp/B0027VFZE6
My jack has gone really well so far. It's pretty light to move around and lifts quickly even though it's a single pump only.
Min height is listed as 90mm. My car is moderately low, I can (just) lift it under the wheel arch with the wheel at full lock. It's a bit fiddly though so I normally just drive the car on some ramps and lift it from the front.
I've found that the real issue with low cars and jacks is not actually the min height, it's the length of the jack body. A medium size jack like this is just not long enough to allow the handle to move up and down when the arm is under the front cross member.
Let us know how you go.
I just cut two pieces of timber with a suitable bevel on one end and drive up on them. They also double as wheel chocks so you don't have to use the handbrake when the brakes are hot
I have to jack mine up just to get the ramps under the tyres - can't drive up them, too low. But I've been using a Repco low profile steel/iron jack for years and it is fine, gets under the car and onto the subframe at the front no issues. I usually put a 600mm bit of 4x2 across the frame to even out the load though. Cost me around $200.
Only thing is its heavy, but thats what trolley wheels are for.
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
