Item: 21st Century Performance by Julian Edgar
Age: New
Condition: New
Price: $120 + freight
Contact: Here or 0431408578
Comments:
This book is now out-of-print.... rare book
21st CENTURY PERFORMANCE is the first high-performance book that covers current automotive technology - and how to modify it for best results.
There's a chapter on how the factory electronic engine-management and EFI systems work, and another on how to make changes to them. Did you know that some brilliant engine-management modifications can be done for almost zero cost? There's the latest in programmable management systems, including hard-to-find fitting and tuning information.
21st Century Performance sorts the fact from fiction on mufflers, catalytic converters and even complete exhausts. The difference in flow of press and mandrel bends, what back-pressure does for performance, which mufflers are noisy and which are restrictive - the best advice is here, supported by detailed test results.
There's a chapter on getting the most from the intake system, from simple but effective air box modifications, right through to designing a new tong-runner dual-length intake manifold. The performance of different air filters, the power gains from modifying intake ducts - it's all included.
How to modify the latest engines - including multi-valve and multi-cam designs - is discussed. Forced induction is covered in detail, with both turbos and superchargers extensively featured. There are also major chapters on intercooling and water injection systems. Boosting the power of a factory turbo car is discussed in step-by-step detail - even how to build two different turbo boost control systems!
And the best thing is that many of the modifications are of the practical, do-it-yourself type, giving proven power gains without breaking the bank. There are numerous results of tests carried out on modified cars - dyno graphs, flow bench tests ~1id on-road performance figures. In fact, there's also a whole chapter on how to test your own car so you can be sure you're always heading in the right performance direction.
If you want to go around corners as well as in a straight line, the upgrading of brakes, suspension, wheels and tires is covered in detail. And because 21st Century PERFORMANCE covers the latest technology, high-power turbo four- wheel-drive cars and active torque split control systems aren't left out. Uniquely, there's also a major chapter on making effective aerodynamic modifications.
And if you simply want to know how the latest in car technology works - from variable flow exhausts to computerised dyno testing, from all-alloy 32-valve V8s to twin sequential turbo engines - 21st Century PERFORMANCE will bring you right up to speed.
Published 2000.
Hard bound, 0ver 350 pages,
Over 500 full colour photographs,
150 diagrams.
ISBN 094721690-1
https://www.sau.com.au/forums/topic/220025-21st-century-perfomance-book/
i think you gotta lower the price or something if your really keen on selling,
Its an outta print book... but more interested to selling to people who have been looking for it, than people who want it for cheap...
I can vouch for this book, its a very interesting read and is very hard to find, especially in Australia.
Good luck with the sale :(
Thanks mate... wouldn't happen to want another one by any chance? :thumbsup:
    • I'd be installing 2x widebands and using the NB simulation outputs to the ECU.
    • Nah, it's different across different engines and as the years went on. R32 era RB20, and hence also RB26, the TPS SWITCH is the idle command. The variable resistor is only for the TCU, as you say. On R33 era RB25 and onwards (but probably not RB26, as they still used the same basic ECU from the R32 era), the idle command is a voltage output of close to 0.45V from the variable resistor.
    • It's actually one of the worst bits of Nissan nomenclature (also compounded by wiring diagrams when the TCU is incorporated in ECU, or, ECU has a passthru to a standalone TCU).... the gripe ~ they call it the TPS, but with an A/T it's actually a combined unit ...TPS (throttle position switch) + TPS (throttle position sensor).... ..by the looks of it (and considering car is A/T) you have this unit... https://www.amayama.com/en/part/nissan/2262002u11 The connector on the flying lead coming out of the unit, is the TPS (throttle position sensor) ...only the TCU reads this. The connector on the unit body, is the TPS (throttle position switch) ...ECU reads this. It has 3 possible values -- throttle closed (idle control contact), open (both contacts open, ECU controls engine...'run' mode), and WOT (full throttle contact closed, ECU changes mapping). When the throttle is closed (idle control contact), this activates what the patent describes as the 'anti stall system' ~ this has the ECU keep the engine at idling speed, regardless of additional load/variances (alternator load mostly, along with engine temp), and drives the IACV solenoid with PWM signal to adjust the idle air admittance to do this. This is actually a specific ECCS software mode, that only gets utilized when the idle control contact is closed. When you rotate the TPS unit as shown, you're opening the idle control contact, which puts ECCS into 'run' mode (no idle control), which obviously is a non-sequitur without the engine started/running ; if the buzzing is coming from the IACV solenoid, then likely ECCS is freaking out, and trying to raise engine rpm 'any way it can'...so it's likely pulling the valve wide open....this is prolly what's going on there. The signal from the connector on the flying lead coming out of the unit (for the TCU), should be around 0.4volts with the throttle closed (idle position) ~ although this does effect low throttle shift points if set wrong, the primary purpose here is to tell TCU engine is at idle (no throttle demand), and in response lower the A/T line pressure ... this is often described as how much 'creep' you get with shifter in D at idle. The way the TPS unit is setup (physically), ensures the idle control contact closes with a high margin on the TPSensor signal wire, so you can rotate the unit on the adjustment slots, to achieve 0.4v whilst knowing the idle control contact is definitely closed. The IACV solenoid is powered by battery voltage via a fuse, and ground switched (PWM) by the ECU. When I check them, I typically remove the harness plug, feed the solenoid battery voltage and switch it to ground via a 5watt bulb test probe ; thing should click wide open, and idle rpm should increase... ...that said though, if it starts & idles with the TPS unit disconnected, and it still stalls when it gets up to operating temperature, it won't be the IACV because it's unused, which would infer something else is winking out...
    • In the context of cam 'upgrader' I mean generally people who upgrade headers/cams - not my specific change. I mean it makes sense that if I had a bigger cam, I may get more false lean readings. So if I went smaller, I'd get less false lean readings. To a point where perhaps stock.. I'd have no false lean readings, according to the ECU. But I'm way richer than stock. My bigger than normal cam in the past also was giving false rich leanings. It's rather odd and doesn't add up or pass the pub test. Realistically what I want is the narrowbands to effectively work as closed loop fuel control and keep my AFR around 14.7 on light sections of the map. Which is of course the purpose of narrowband CL fuel control. So if I can change the switch points so the NB's target 14.7 (as read by my WB) then this should be fine. Haven't actually tested to see what the changed switchpoints actually result in - car needs to be in a position it can idle for awhile to do that. I suspect it will be a troublesome 15 min drive home with lots of stalling and way too rich/lean transient nightmare bucking away for that first drive at 2am or whevener it ends up being. Hopefully it's all tune-able. Realistically it should be. This is a very mild cam.
    • Messing with narrowband switchovers is a terrible bandaid. I don't want to think about it. You are a cam "upgrader" only in concept. As you said, your new cam is actually smaller, so it's technically a downgrade. OK, likely a very small downgrade, but nevertheless. But the big thing that will be the most likely suspect is the change of the advance angle. That change could be equivalent to a substantial decrease in cam lobe duration. I haven't gone to the effort of trying to think about what your change would actually cause. But until someone (you, me (unlikely), Matt, someone else) does so and comes to a conclusion about the effect, it remains a possibility that that is the change that is causing what you're seeing.
