Well looks like im up for a new clutch on my R33 but really not sure on which one to get. Im only aiming for around 200rwkw and would be nice to get one that isnt super heavy. I was wondering what the differences are in the clutches and which would be better. Im not sure what it means by Organic, 5 Puk Button and Cushion button?
Heavy Duty Organic clutch kit (240rwkw), $335
Heavy Duty 5 Puk Button clutch kit (300rwkw) , $439
Heavy Duty Cushion Button clutch kit (260rwkw) , $445
Any help would be Great!
Thanks!! :thumbsup:
https://www.sau.com.au/forums/topic/220040-new-clutch-for-r33-skyline/
Hey Matt,
The organic is still a full faced clutch but is just a different make up/material and a more heavy load presure plate.
The 5 puck looks like a star and it does grab very quickly and is not so good in traffic for long periods of time as it is pretty heavy due to the pressure plate it has.
And the cusioned is a full face but with cushioning tabs on it, but wond be too much fdifferent to drive with as oposed to the organic, but you will definalty know the difference from stock, i think every body stalls when they first get in there car with a new clutch, i did lol
I have a cushioned button clutch and it has very good pedel feel and is smooth to operate, but in saying that the cluth is only has to be about half of the standard in terms of travel to be fully out, and also grabs a lot hard than standard but overall i am very happy with it and is nice to drive with and is quite accepable to drive in traffic also, but does make the car feel like you getting your power down, i had the standard clutch and it was starting to slip so thats why, but it lasted from factory so that pretty good :teehee:
Hope this helps, By the way if you are positive 200 rwkw the organic will be fine but be sure first as you dont want
to change it later , if seeking more power.
Edited by gtstcoupe
    • Dose is unaware just how much fun 145-150kw would be in a 2.5L NC MX5. It would be one of the most fun things to drive to ever grace SAU.
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
