hey guys,
I got a ps3, aus PAL version, and i want to get the uncut version of gta4, I know they are all region free etc etc, but someone told me it MIGHT not work on every tv, i have a fairly standard tv unit, nothing crash hot, good size, maximum 5 years old. my question is,
would it have a problem playing the game on that t.v?
in future ill be buying a massive lcd tv would i have a problem with my lcd playing region free games too?
thanks guys.. appreciate any feedback
Rami
hey guys,
Rami
It isn't the tv that has region problems, its the DVD player - in this case the PS3. It SHOULD work, I'm not 100% sure but i think games dont have regions , unlike DVD movies.
Incorrect. The TV must support NTSC format. Australia runs on PAL but you should be right mate, most TV's these days support both PAL and NTSC formats.
The PS3 games are 100% region free, no worries there. The blu-rays however are region encoded.
Edited by AZN25T
it should work fine
I dont know why you would buy, the only thing that is different is how you interact with the hookers and apparently one cut scene.
Why dont you save your $70 odd and go see a real hooker
ppfft giveing a shit about cartoon porn
As mentioned your TV needs to support NTSC but most TV's do now and have done so for years. If unsure there may be a sticker on the back of the TV that lists model number and such that should also state if it is PAL/NTSC.
Only difference between Aus and USA versions so far is the hookers. I haven't found this missing footage yet.
it should work fine
well, you may be right, but i actually went to buy the aus version, and i asked the guy behind the counter whats the difference, he told me aus version is 1gb less than the usa version, and knowing ps3 games are REALLY small games for some reason... i opted for the us version.
does anyone agree with me on that? i finished need for speed pro street in no time, call of duty 4 in a week, fifa 08 u can only play for 5 years... and virtua tennis is piss easy. im not a freak i only play after work for max 1 hour...
and for the guy who told me about the 1gb difference.. well i dont know if its true.. he had huge glasses and lost a sale for telln me that so who knows.. thanks for all the replies by the way!
    • Should shit that in as for the driver ability probably not
    • Trying to find the plastic under cover for an 04' Forester X. The main under cover that covers most of the front of the vehicle under the engine. This has turned out to be a crazy experience. Normally I can find parts for vehicles, if I have the correct info, no problem. But not this! The Forester is a non-turbo btw. In a Forester parts catalog, for model years 03'-06', it shows part# 56410SA070 as being the correct part. So I go to the local Subaru dealership's website to order it. I type in the part#, hit search and there it is, the under cover. "DOES THIS PART FIT YOUR VEHICLE?" I type in my VIN# and sure enough, "This Part Does Not Fit Your Vehicle. See Similar Parts For Your Vehicle." I click on that and part# 56410SA000 comes up. Looks absolutely nothing like the previous part. Not even close. So I go to a different Subaru dealer website and put in that 2nd part# (56410SA000) and "This Part Has Been Replaced By" 56410SA070, which is the first part I looked up. I thought OK, makes sense. They replaced the strange looking part, with the one I looked up first, so I add it to the cart. "Does This Part Fit Your Vehicle?" I type in my VIN#, and sure enough, "This Part Does Not Fit Your Vehicle." I've basically been doing this with various parts suppliers and dealerships, for the past 4 hours! Does anyone know what the hell is going on?? Thanks in advance!
    • have you rotated the car yet? if so how smooth was it?
    • And finally, I had the driver's side airbox off while adding a long drain hose under the oil can to down near the oil filter. Doesn't look good, it has definitely had an turbo oil seal leak and looks like it has been for a long time.....guess I'll have to get a pair of highflows to put on the shelf It's also worth mentioning it has a really strange clamp between the bottom of the airflow meter (which has a big barb/lip on it) and the intake pipe. I've used the magic of MSPaint to show, basically you have to clip out those 2 steel springs which unlocks the hose from the AFM. I used 2 flat screwdrivers, the spring sort of clips into the unlocked position. Reassembly you just pop them both back flat once the hose is far enough up the AFM that the spring clamp is above the barb. Weird to use but much more convenient once your'e used to it compared to trying to do up a hose clamp under the airbox like on 32 GTR
    • The other thing I started was a fire extinguisher bracket.  As with a few other cars previously (350z, Leaf), I'm going to add a bracket between the navigator seat's front bolts, then mount the extinguisher on that. Unfortunately Nissan (probably the same engineer who did the A/T fluid interwarmer) decided that the front seat brackets would be recessed and uneven so the bracket shape was a bit tricky; I ended up doing 1 part under each seat mount (the large hole is because there is a flange under the seat mount to allow for the carpet thickness)   and then a horizontal part between those 2 No final pic yet as the paint needs to dry, I'll post up once that's done
