Hey there guys,
I just bought a new turbo off a mate for $300.
He and I are unsure of what brand it is so I was hoping that yous can help me.
It is a TO4E turbo and the Part number is T3/T4, it has M12 stamped on the mouth of the turbo and A/R.50 and A/R.63, M58, M2 and WSHH stamped on the exhaust side.
Can anyone tell me what brand it is if it is any good to bolt to a RB25/30 engine?
Thanks guys.
Shaun.
https://www.sau.com.au/forums/topic/220078-to4e-turbo/
30-34psi? lol... dude... a old bush bearing t04e from no-mans land would be lucky to hold 20psi for extended periods.
My bet would be it'll desintergrate if you try run that much boost through it, even 20psi would be an issue.
However... It raises the question, do you even know how a turbocharger works?
Its not just a case of "running 30psi". If the compressor wheel reaches its flow limit, no amount of boost you try and run will make anymore power, just hot air causing detonation.
If you've indeed built a decent 25/30, put a decent turbo onto it. And anything decent is upwards ofr $1600
https://www.sau.com.au/forums/topic/220078-to4e-turbo/#findComment-3882437
Who cares wether it is a Garrett, Turbonetics, HKS, APexi or god himself created it in a workshop in Switzerland, it's a T04e, an old crap desgined turbo which is outdated in every single way. There is a reason you got it for $300. Honestly mate, if you have spent the money on the engine build fork out the extra couple of grand and get yourself a decent modern turbo. You shall be very dissapointed by the TO4e just like many others have that soon upgraded to something different.
https://www.sau.com.au/forums/topic/220078-to4e-turbo/#findComment-3882912
whether it is a good turbo for the dollars or what.. the fact is no it will not be efficient at 30+psi.. however regarding bolting it up; that exhaust manifold flange looks t3 (suit rb20/25), however the dump flange will not suit a skyline. you will also need to block or loop/link your water lines.
https://www.sau.com.au/forums/topic/220078-to4e-turbo/#findComment-3883712
^ I dont know. He has a chrome top mount manifold but he bought that seperate... Or so he says.
I dont thik it's garrett at all.... I dont even think it is greddy. Oh well. it's only $300 down the tube.
Anyway, it aint going in the skyline anymore.... We have an old 93 triton t deisel that we are gonna whack it on now...
Does anyone know where I can get a waistgate for it?? or can I just buy universal one???
https://www.sau.com.au/forums/topic/220078-to4e-turbo/#findComment-3888283
From what I can see in the pics so don't hold me to this .
To me it looks like a copy of a T04E compressor housing and a copy of a Garrett "5 bolt" integral (internal) gated Ford style exhaust housing .
The turbine looks more like a 12 bladed Mitsubishi (TD05/06 ?) rather than anything Garrett I recall seeing .
Center bearing is non water jacketed so not the best in a petrol fired EGT application .
Even in our Pacific Paseo I'd reckon it would be difficult to manufacture and market a $300 turbocharger .
A .
https://www.sau.com.au/forums/topic/220078-to4e-turbo/#findComment-3888480
  • 8 months later...
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
