Hi guys, just wondering if anybody has relocated their Power steering reservoir in the engine bay on a R32 GTR.
Basically i installed a big single turbo and the pipe that joins to the intercooler piping fouls with the P/S tank.
Theres not much room for me to relocate it as the Tank itself is quite tall and fouls with my bonnet.
The only place i can see that is suitable is where my charcoal canister is but then i need to find a place for that to go.
So my question is. Where can i move the P/S tank to?
Can i cut the tank down in size and reweld it?
Can i get a tank custom made out of aluminium?
ANy help would be appreciated thanks
yes...custom tank out of ally can be made. Ive mounted mine on the radiator support panel just behind the passenger headlight.
Is there any criteria you need to meet when fabricating?
As in do you need to meet a certain capacity (litres) etc, and or design it in any special way with chambers etc.
Have you got a pic of where yours is mounted?
Thanks heaps.
there are some pre made aftermarket ones available - Felixity69 in the rb30 subforum used one.
i have seen customs made up, i would just baffle it to ensure that the feed to the pump is always covered in fluid, or you'll get major bleeding issues.
    • Hey, like MBS206 mentioned; I dropped off my short block and rotating assembly Monday. With a quick verification, he believes he can clear it up with just a hone and new rings but he will confirm once the rotating assembly is out. If I were you, I would either go stroker or just replace the block if it does need to be bored over to next size. Block is cheaper then forged pistons.
    • live in the UK, and London has introduced a Low Emission Zone (LEZ) that requires individuals to pay £13 if their car doesn’t meet the required emissions standards.   The standard specifies that NOx emissions must be less than 0.08 g/km (i.e., the vehicle must meet Euro 4 standards or better, which generally results in NOx levels of around 0.08 grams per kilometer).   I reached out to Nissan UK, and they advised me to contact Nissan Japan directly. Does anyone have contact details for Nissan Japan or any certifications of conformity that show the emission details or NOx levels for the RB25DET engine?   Any guidance would be greatly appreciated.
    • these guys recommended to me and supplied custom 4 inch mufflers, couldn't be happier. They will spec a muffler to your preferred level of sound and know RB's well.  https://spmufflers.com.au/
    • Yeah this used to happen to me every year and a quick call would at least raise the agreed value back up / reduce the premium, but usually both.    That said for the first time on the renewal this year our agreed values went up or stayed the same over the fleet and the premium came down so that was a nice surprise.
    • I don't even go that hard core. I just say "how do you expect me to stay, when you increase my premium, and reduce the value of the car?"   Then play a game of shut the f**k up. Most of the time it's a computer that did the adjustment, and the people will happily change it around for you.
