Ok..according to this website:
http://translate.google.com.au/translate?u...en&ie=UTF-8
My car actually comes with Bluetooth & Voice command as a factory option.
◆ 3 カーウイングスナビゲーションシステム(DVD方式)(電動昇降式7インチワイド液晶モニター、TV、ハンズフリーフォン、VICS[FM多重]、ボイスコマンド、車両情報表示機能付)、ステアリングスイッチ(オーディオ、ボイスコマンド、ハンズフリーフォン) KAUINGUSUNABIGESHONSHISUTEMU (DVD format) (motorized 7-inch wide-screen LCD monitor-up, TV, Bluetooth Handsfree, VICS [FM multiplex, voice commands, vehicle information display capability), steering switches (audio, voice command, Bluetooth Handsfree).
Searched G35driver on ways to pair the phone and according to their site, you need to press the button on the steering wheel with the pic of the man who looks like he's shouting and say "pair phone".
Anyways, tried that and nothing happened...BUT found out tht the bluetooth is linked to the factory nav unit..so stuck the CD in waited or it to load and then pressed the steering wheel switch.
This is what came up:
A girls voice muttered something in Jap which I presume is saying something like " say a command"
I tried "pair phone" and the girl muttered something which I gather is "incorrect command or not found"
I tried "TV" and it brought me to the TV screen! - so my voice command works!
I tried a few other words in english which actually brought me to different menus including the trip computer.
Below are a few screens which you might find interesting:
Built in GPS?
Search location?
Nearest gas station?
Address:
So to sum it up, I believe bluetooth is there somewhere I just need someone to tell me how to say PAIR PHONE in Japanese! ;)
do you have the phone buttons on the steering wheel, or the standard audio buttons or both?
from memory, bluetooth was only available on the series 2 cars..
Yes I have the phone button, voice command button and the volume and track buttons...and yea mine is a series 2.
lol.. bluetooth does come stock with the gen 2 premium v35's... I would assume that it would be done via the phone menu rather than the voice command. What happens when you press the phone button?
My Cima has the voice command menu.. ill go through a quick run down of the commands:
Eea Con On - Air con on
Eea con off - air con off
shiii di - cd
efu emm - fm
ai emm - am
terebi - tv
emu dee chenga- md changer
dee bee dee - dvd
The most handy ones require u to learn how to count in jap which allow you to say the radio station or set the temperature
eg)
kyu hyaku go juu yon - 954 2ue
ni juu do - 20 degrees
you can also say commando risto which will display all the different commands.. if you want to take a photo of the different tabs ill let u know if ive missed something.. especially under the phone tab which should say フォン up the top.. also the carwings stuff sounds interesting ive never really understood wat carwings was all about..
anyways have fun
cheers,
k
shiii di - cd
efu emm - fm
ai emm - am
terebi - tv
dee bee dee - dvd
eg)
anyways have fun
cheers,
k
Thanks KArim!
I will definately give those a go later. However, like any bluetooth device the phone is connected to, it needs to be paired to the device first before it will work. I am still missing the command for putting the V35 bluetooth in pairing mode so my phone can detect it. Any ideas? Have you managed to get bluetooth working on yours and how did you do it?
Cheers,
Jon
Edited by n15m0
I could've sworn i replied to this last nite.. how bizzarre..
anyway.. i doubt you will be pairing your phone via voice command.. wat comes up when you hit the actual phone button? I assume it will take you into the phone menu where u will set all that stuff up.. send through shots and i will guide you through it..
When I hit the phone button an error message comes up in Jap and then disappears (attached screen shot)...I assumed that was for the hard wired phone which incidently I also have that connector in the center arm rest which only fits a jap handset.
Only reason I figured it was to be paired via voice command is because of this:
http://www.infiniti.com/bluetooth/setup.ht...&modelid=15
This is the setup guide for the G35s in US.
If you can tell me what that jap message says might give us a clue.
the jap is saying "connecting, or still verifying". if it stalls there, then it's probably not recognising the phone, may be u should try a few different phones?
Edited by GEXer
hmm ive done some readin... might have some bad news.. i dont think it actually does have bluetooth.. the v36 definately does but i dont think yours does... the translation you got was pretty bad it says
It actually says handsfree phone not bluetooth handsfree
Also does the drive have the bluetooth logo on it? If it does maybe I'm wrong.. otherwise its just handsfree via the cable >.<
interesting read :P
what does "carwings" mean - it has that on one of the photos.....
Hi eMsta,
This is what I found on Carwings, very cool option.
Makes me wish I saved a bit longer and bought a newer model!
http://www.nissan-global.com/EN/DOCUMENT/P...carwings_en.pdf
