Ok..according to this website:
http://translate.google.com.au/translate?u...en&ie=UTF-8
My car actually comes with Bluetooth & Voice command as a factory option.
◆ 3 カーウイングスナビゲーションシステム(DVD方式)(電動昇降式7インチワイド液晶モニター、TV、ハンズフリーフォン、VICS[FM多重]、ボイスコマンド、車両情報表示機能付)、ステアリングスイッチ(オーディオ、ボイスコマンド、ハンズフリーフォン) KAUINGUSUNABIGESHONSHISUTEMU (DVD format) (motorized 7-inch wide-screen LCD monitor-up, TV, Bluetooth Handsfree, VICS [FM multiplex, voice commands, vehicle information display capability), steering switches (audio, voice command, Bluetooth Handsfree).
Searched G35driver on ways to pair the phone and according to their site, you need to press the button on the steering wheel with the pic of the man who looks like he's shouting and say "pair phone".
Anyways, tried that and nothing happened...BUT found out tht the bluetooth is linked to the factory nav unit..so stuck the CD in waited or it to load and then pressed the steering wheel switch.
This is what came up:
A girls voice muttered something in Jap which I presume is saying something like " say a command"
I tried "pair phone" and the girl muttered something which I gather is "incorrect command or not found"
I tried "TV" and it brought me to the TV screen! - so my voice command works!
I tried a few other words in english which actually brought me to different menus including the trip computer.
Below are a few screens which you might find interesting:
Built in GPS?
Search location?
Nearest gas station?
Address:
So to sum it up, I believe bluetooth is there somewhere I just need someone to tell me how to say PAIR PHONE in Japanese! ;)
do you have the phone buttons on the steering wheel, or the standard audio buttons or both?
from memory, bluetooth was only available on the series 2 cars..
Yes I have the phone button, voice command button and the volume and track buttons...and yea mine is a series 2.
lol.. bluetooth does come stock with the gen 2 premium v35's... I would assume that it would be done via the phone menu rather than the voice command. What happens when you press the phone button?
My Cima has the voice command menu.. ill go through a quick run down of the commands:
Eea Con On - Air con on
Eea con off - air con off
shiii di - cd
efu emm - fm
ai emm - am
terebi - tv
emu dee chenga- md changer
dee bee dee - dvd
The most handy ones require u to learn how to count in jap which allow you to say the radio station or set the temperature
eg)
kyu hyaku go juu yon - 954 2ue
ni juu do - 20 degrees
you can also say commando risto which will display all the different commands.. if you want to take a photo of the different tabs ill let u know if ive missed something.. especially under the phone tab which should say フォン up the top.. also the carwings stuff sounds interesting ive never really understood wat carwings was all about..
anyways have fun
cheers,
k
shiii di - cd
efu emm - fm
ai emm - am
terebi - tv
dee bee dee - dvd
eg)
anyways have fun
cheers,
k
Thanks KArim!
I will definately give those a go later. However, like any bluetooth device the phone is connected to, it needs to be paired to the device first before it will work. I am still missing the command for putting the V35 bluetooth in pairing mode so my phone can detect it. Any ideas? Have you managed to get bluetooth working on yours and how did you do it?
Cheers,
Jon
Edited by n15m0
I could've sworn i replied to this last nite.. how bizzarre..
anyway.. i doubt you will be pairing your phone via voice command.. wat comes up when you hit the actual phone button? I assume it will take you into the phone menu where u will set all that stuff up.. send through shots and i will guide you through it..
When I hit the phone button an error message comes up in Jap and then disappears (attached screen shot)...I assumed that was for the hard wired phone which incidently I also have that connector in the center arm rest which only fits a jap handset.
Only reason I figured it was to be paired via voice command is because of this:
http://www.infiniti.com/bluetooth/setup.ht...&modelid=15
This is the setup guide for the G35s in US.
If you can tell me what that jap message says might give us a clue.
the jap is saying "connecting, or still verifying". if it stalls there, then it's probably not recognising the phone, may be u should try a few different phones?
Edited by GEXer
hmm ive done some readin... might have some bad news.. i dont think it actually does have bluetooth.. the v36 definately does but i dont think yours does... the translation you got was pretty bad it says
It actually says handsfree phone not bluetooth handsfree
Also does the drive have the bluetooth logo on it? If it does maybe I'm wrong.. otherwise its just handsfree via the cable >.<
interesting read :P
what does "carwings" mean - it has that on one of the photos.....
Hi eMsta,
This is what I found on Carwings, very cool option.
Makes me wish I saved a bit longer and bought a newer model!
http://www.nissan-global.com/EN/DOCUMENT/P...carwings_en.pdf
    • Good afternoon Team , just a quick update on performance mods  Current Mods list (Installed) HKS - Power Editor (Came with the car) looks to be some kind of boost controller RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Cat Back  RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Front Pipe AMS  - INFINITI Q50/Q60 RED ALPHA COLD AIR INTAKE KIT AMS  - Performance Heat Exchanger Intercooler Not Yet AMS Alpha Performance Full Race Down Pipes  - to be installed in May
    • I'd be installing 2x widebands and using the NB simulation outputs to the ECU.
    • Nah, it's different across different engines and as the years went on. R32 era RB20, and hence also RB26, the TPS SWITCH is the idle command. The variable resistor is only for the TCU, as you say. On R33 era RB25 and onwards (but probably not RB26, as they still used the same basic ECU from the R32 era), the idle command is a voltage output of close to 0.45V from the variable resistor.
    • It's actually one of the worst bits of Nissan nomenclature (also compounded by wiring diagrams when the TCU is incorporated in ECU, or, ECU has a passthru to a standalone TCU).... the gripe ~ they call it the TPS, but with an A/T it's actually a combined unit ...TPS (throttle position switch) + TPS (throttle position sensor).... ..by the looks of it (and considering car is A/T) you have this unit... https://www.amayama.com/en/part/nissan/2262002u11 The connector on the flying lead coming out of the unit, is the TPS (throttle position sensor) ...only the TCU reads this. The connector on the unit body, is the TPS (throttle position switch) ...ECU reads this. It has 3 possible values -- throttle closed (idle control contact), open (both contacts open, ECU controls engine...'run' mode), and WOT (full throttle contact closed, ECU changes mapping). When the throttle is closed (idle control contact), this activates what the patent describes as the 'anti stall system' ~ this has the ECU keep the engine at idling speed, regardless of additional load/variances (alternator load mostly, along with engine temp), and drives the IACV solenoid with PWM signal to adjust the idle air admittance to do this. This is actually a specific ECCS software mode, that only gets utilized when the idle control contact is closed. When you rotate the TPS unit as shown, you're opening the idle control contact, which puts ECCS into 'run' mode (no idle control), which obviously is a non-sequitur without the engine started/running ; if the buzzing is coming from the IACV solenoid, then likely ECCS is freaking out, and trying to raise engine rpm 'any way it can'...so it's likely pulling the valve wide open....this is prolly what's going on there. The signal from the connector on the flying lead coming out of the unit (for the TCU), should be around 0.4volts with the throttle closed (idle position) ~ although this does effect low throttle shift points if set wrong, the primary purpose here is to tell TCU engine is at idle (no throttle demand), and in response lower the A/T line pressure ... this is often described as how much 'creep' you get with shifter in D at idle. The way the TPS unit is setup (physically), ensures the idle control contact closes with a high margin on the TPSensor signal wire, so you can rotate the unit on the adjustment slots, to achieve 0.4v whilst knowing the idle control contact is definitely closed. The IACV solenoid is powered by battery voltage via a fuse, and ground switched (PWM) by the ECU. When I check them, I typically remove the harness plug, feed the solenoid battery voltage and switch it to ground via a 5watt bulb test probe ; thing should click wide open, and idle rpm should increase... ...that said though, if it starts & idles with the TPS unit disconnected, and it still stalls when it gets up to operating temperature, it won't be the IACV because it's unused, which would infer something else is winking out...
    • In the context of cam 'upgrader' I mean generally people who upgrade headers/cams - not my specific change. I mean it makes sense that if I had a bigger cam, I may get more false lean readings. So if I went smaller, I'd get less false lean readings. To a point where perhaps stock.. I'd have no false lean readings, according to the ECU. But I'm way richer than stock. My bigger than normal cam in the past also was giving false rich leanings. It's rather odd and doesn't add up or pass the pub test. Realistically what I want is the narrowbands to effectively work as closed loop fuel control and keep my AFR around 14.7 on light sections of the map. Which is of course the purpose of narrowband CL fuel control. So if I can change the switch points so the NB's target 14.7 (as read by my WB) then this should be fine. Haven't actually tested to see what the changed switchpoints actually result in - car needs to be in a position it can idle for awhile to do that. I suspect it will be a troublesome 15 min drive home with lots of stalling and way too rich/lean transient nightmare bucking away for that first drive at 2am or whevener it ends up being. Hopefully it's all tune-able. Realistically it should be. This is a very mild cam.
