Hi guys,
Just wanted to see whos up for meeting up 2mro nite at 7.30pm Bunnings Car Park in Sunshine!
Would be good to meet some new people :D
-Ferah
EDIT: just reliased i posted this at 12.38am lol so the title should really be called 'west meet tonight!' (21-5-08)
Edited by DNGRUS
https://www.sau.com.au/forums/topic/220145-west-meet-2mro-nite/
  • Replies 48
What a great idea, Ferah - I'll definitely be there @ 7:30pm sharp. Perhaps everyone meet closer to the main entrance so that we don't get lost.
Any ideas where to go tomorrow night? A coffee to get to know some new faces would be nice.
Ferah, the next one if you want to organise, post it up week in advanced... Not night before LOL!
Then I can get some East Siders down and have a big turn out.
Edited by (00)SKYLINE(00)
  krzysiu said:
East meets>west meets
LOL!
Yeah, it be good if we can do a East meets West. (BTW anyone from the North and South?)
I been twice and the 2nd time I got revhed01 down too.
Can you still drive krzysiu and is eMsta thinking of a way to get the meets via PM or something?
  Spunky Munky said:
Great - try fellas... it would be nice to get to know some new faces.
An empty car park with Skylines - what more can you ask for in life?
wouldnt it be nice if bunnings was not a hardwarestore but one gigantic auto shop... and we were allowed tot ake asmuch as we could... but thats asking too much
see you guys there tonight in the single turbo shitter
Guest
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
