hey guys, after reading NYTSKY's thread on his engine build i thought i might do one myself :woot: its great to get all sorts of feedback and information from fellow builders/enthusiests...
It all started after i put a GT2876 onto my rb20 with a few other goodies, then just before i got it tuned i did a quick compression test... 150 across the board...until i hit number 5, which was 95. put some oil into the cylinder and i then got 195 in cylinder 1... which told me the rings wernt in 100% working order and number 5 valve was leaking. which...from a 18yr old RB20 with 212,000 on it thats never let me down before, i expected the results, just didnt want them.
so i decided to refresh the 20, worked out the costs, and thought it would be cheaper to just put a 25 in there... then got offered a RB25de out of a r32 for $500... then the RB25-30 work started :P
Here are the Parts iv got/ordered so far.
CP Pistons/Rings
Spool Rods/ ARP Rod bolts
Stainless Steel Valves
Ross Balancer
N1 Oil Pump
Geniun Nissan Headgasket (alot of people are refering back to these for there builds)
Tomie Valve Springs
Head has been preped, ported a fraction.
Tomie Oil Resprictors
Oil Collar
Im getting it balanced from the Balancer right to the Clutch.
Chambers will be CC'd.
Using ACL Race bearings as soon as i know what sizes i need.
i also have a microtech LTX12 with ignitors etc to run it all.
i dont make alot of money so i just been saving and buying the next parts il be needing in the build process, hence why i havnt looked into Fuel Set-up yet or Cam Gears/shafts.
the block goes to the machinests in a day or 2.
any extra info or questions will be greatly appreiciated, whats with this water gallery that doesnt get fully blocked or something?
Cheers
CJ
ps, il add more later :) thanks for reading
https://www.sau.com.au/forums/topic/220157-cjs-engine-build/
  • Replies 62
yeh il get pics ASAP.
what would people prefer out of the ORC clutch RMS is selling (twin plate, 709 version) or should i go the Exedy hyper twin from Kudos motorsport? anyone had experience with these clutchs?
Thanks
CJ
As far as I know, the ORC is slightly cheaper than the Exedy Hyper Twin. Im using the Exedy, and no complaints here definitely, but for some reason the pedal is slightly lighter with the ORC twin's ive driven.
That would just be because of a heavier or lighter pressure plate??
Just because the ORC is cheaper, doesnt mean its worse?? (asking a question, not trying to start a argument lol)
CJ
Warning to anyone... if you call jim berry, make sure you got some time to chat! lol. (as everyone told me)
he is making me a custom one now :O after i get the clutch then i can get the engine balanced :O
things move so slow with bigger engine builds :D
CJ
GEt pics i keen to watch this build too, they are so influential. i am re-doing an r32, not engine but damaged rear end i picked it up a few weeks back. anyone keen on a thread? (sorry to hi-jak)
has anyone got pics of a GT42R under the bonnet of a R32 with a 30bottom on it...? (has to be 30 bottom becuase of the height difference)
i can grab a brand new 42R for a good price (veeeery good) and im just wondering if il have enough room between the strut tower, tappet covers and the bonnet.
Cheers
CJ
ps, yeh NYTSKY i ran out of gas for my blow torch :D
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
