  • Replies 62
got my clutch this morning :P
also thinking about using rb26 covers and such, they look much better with the breathers at the back not up the front...
will i have any problems using 26 tappet covers? iv heard il have to use 26 cam gear covers also? (what if i went clear?)
Cheers
CJ
  • 3 weeks later...
Full monty clutch, hope it handles...
all the work is either getting done by myself or a good friend who works for ricky stephans (some people would know that name in the drag racing scene)
top guys to deal with though, and close to my work, so we can transport gear to them easily. got to love trade discount lol.
  • 2 years later...
WELL.... After a few years, career change, city move, and a give up all together on this motor, it is finally running!!!
its been that long that i hardly remember all the parts used!
ill try and upload some photos but currently without a good tune its just pushed out 424.6HP on 13psi. im now running it in and will go back in 2-3 weeks for a proper tune at 13psi then a 20 and a 25... getting talked into a E85 tune also haha.
PLEASE ask me any questions you can think of and il try and get the spec's/answers.
Car has been sittin for that long that the front coilovers have seized and the rears have leaked and bounce away...
Just ordered a new set of coilovers, slotted rotors and new brake pads.
kind of surprised that after all this time the tyres havnt got flat spots or the car hasnt fallen apart with rust...lol
Wanted to go the 42R but i thought it would be to laggy, got a 35R on it now, but it builds boost from 2500rpm and full song so early...
ill see how it feels after the run in and tune and ill decide if i want to throw a 42 on it. :D
It's a 6boost one, ill try and get some better pics of it if you like.
Looking forward to getting it out of the run in tune tho, quite heavy on the fuel at the moment to be on the safe side.
yeh it was down there, looking pretty sad on the outside hey!? cant wait to get rid of those damn doors haha
Yeah...going to have to agree with the doors. Rims could do with a change too, engine is a keeper though.
Then again, I need a new engine and would be more than happy to take it off your hands lol
yeh, well picked up the car as a 5sp manual rb20det for $2200, then $2000 for bodykit/paint/tint, and the wheels were a straight swap for my standard gtst rims.
so ive spent the money on the motor and now everything can be worked up to go with it :)
been a budget car untill it come to the motor.
Sleeper as hell man. Also a owner of a R32 Gtst, just had the engine kill itself so a 25 with a plazman plenum and some other goodies will be calling the engine bay home soonish care of Trent and the rest of the Mercury guys.
Nothing but good cars rolling out of there, my mates S13 (PRN 13) is down there atm receiving a new engine and fuel system.
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
