Hi All,
I bought myself a Silver 03 V35 coupe a couple of months ago and just recently have noticed in the morning when leaving for work moments after i start and head up a hill the Slip, VDC off & Handbrake lights come on stay on.
Now this has happened once before and i had been able to turn off the car put in park and wait a few secs start again and then the lights dissapeared.
but now when i do the above they just come back on.
anyone have any idea as to what could be the cause?
faulty electrics, cold engine, car not liking going up a hill first thing in the morning??
appreciate any feedback
Hi All,
Hey mate,
Sounds like the ECU is picking up a fault somewhere and there for flashing up the lights.
Does the car do anything like loose power, not go aboev certain rpm? If yes then it's definately going into "Limp Mode" which basically just means the car is recognising something is not right and so it's looking after itself.
Best thing to do would be to find someone who run a check and see if any fault codes pop up. Where are you located?
Oh, and welcome to SAU :-)
Had this happen before and also another member and told him to do the same thing and it worked , Change your brake pads they need changing
Hey nismo,what brand/type pads did you buy and how much?
did you machine the discs or did you need new ones?
i was quoted $220 per disc for the fronts from nissan randwick
Hey mate,
Hey nismo thanks for the welcome and the advice
no power loss at all but the brakes are squeeling like no tommorow its getting rather annoying.
Im located in sydney city area and was thinking of taking it to Nissan @ Randwick.
heard they want $220 per disc and $80 per pad...how does that sound?
what kind of brake pad r they using? js the OEM nissan pads found on the Z?
bendix for the pads maybe,
but rda slotted for $220-nah....where are you shopping to get rdas at that price?
http://www.skylinesaustralia.com/forums/Rd...Gr-t200718.html
No price for V35/350z but prices aren't that far off the nissan ones.
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring over comms. Everything critical must still be hard wired.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
