hey guyz can you please tell me which rear bumper would suit my r33 im getting the rear boot drift lip as well but below is a pic of the car to tell me what rear bar you would get? Nothing to over the top cause it still has to match the lines of the side skirts :rofl:
Also it will be lower after this weekend getting coil overs yay
https://www.sau.com.au/forums/topic/220223-rear-bumper-which-one/
^^ Yeah they are.
Just do a search in the For Sale Threads. If not bodykit places will have them.
ds15 is selling them. Just ask to see if there still for sale.
http://www.skylinesaustralia.com/forums/Fs...3+gtr+rear+pods
^^ Yeah they are.
Cheers thanks dude
sorry to hijack,
but will a rear bar like the xplosive fit a r33 sedan?
i want something to bring the rear of the car down lower a little as it sits so much higher than the rest.
just something subtle. but i cant seem to find much info regarding 4 door kits and fitment etc
    • Just install a grease nipple into the centre of the outer steel of the FUCA. Make sure the bushes aren't long enough to touch each other underneath that nipple. Cut a few mm off each if need be. Then you can push grease in there while it is all assembled. That was the very first thing I did (to all 4 ends) of the FUCAs on my 32 when I put Whiteline adjustable bushes into them. They would squeeze the grease out real fast, and I could squeeze it back in faster.
    • @GTSBoy I found the issue (sort of) when I took apart the bushing again, it was completely dry inside! When I experimented with it, all the grease would push out when I would compress the bushings. I wonder if this has anything to do with me putting in the poly bush first on both sides and then pushing in the metal barrel. Maybe I should have put in the metal barrel first then the rubber bushings so the spread pattern is different.   It's fixed (for now).
    • Just redid that entire job. 4 hours, but tightened everything properly. Had to jack the rotor instead of having the car on blocks as there was no room for the FUCA arms to tighten and the j arm. All good now. Cheers for the help!
    • I would sell those side feeds before you hydra-lock a motor. I won't say too much about Yellow Jackets because I'll hurt people's feelings, however ask those that tune RBs day in/out what they think of them.
    • The 1000ccs are side feeds but they're not currently installed, had my old factory ones in for leak testing purposes, only decided on them because front facing plenums and good top feed rail kits are out of my budget at the moment, are they really that problematic? Had a set of yellow jackets that lasted me 5 years, no real issues, only replaced them chasing this misfire issue that ended up not being ignition related 😄
