I believe that it meant to make a bit of a racket with pedal in, can't see how going around a corner with pedal out could possibly be a clutch issue though. Maybe something undercar was left a bit loose or shifted a bit closer to something else and as the car goes around the corner, it now moves against another bit and makes a noise?
What is the clutch like to drive compare to the original?
james.
https://www.sau.com.au/forums/topic/220238-orc-709d-rattle/#findComment-3884757
Haha, thought so. The clutch is overall awesome, bites very hard but can still be slipped a bit. Was stuck in peak hr on the freeway a few times now and no problems at all crawling slowly...
I’ve got a nismo big operating cylinder and nismo braided clutch hose to, the pedal is very light.
https://www.sau.com.au/forums/topic/220238-orc-709d-rattle/#findComment-3887209
Not shure actualy, the wrokshop did that part of the build.... I just handed them everything that you gave me... When you get yours in tell me how it feels/sounds...
Mine took a little bit of geting use to as it does bite quick/hard but after a while you can drive it normaly without realy thinking about it much
https://www.sau.com.au/forums/topic/220238-orc-709d-rattle/#findComment-3892630
