  • Replies 67
  • 1 month later...
its still on a very safe tune
i told my tuner to keep on going untill it starts running into problems like pinging but we both changed our minds because of the standard bottom end
so its still on a very safe tune normally i would keep on going for more power untill it starts running into problems and then back of to a safe zone but i was happy with 360kw so we left it at that
Edited by STR8E180
dude, why is the intake temp less then the ambient temp ! I assume the tuner left the temp probe on the dyno.
Your reading will be lower then others.
Also explains why you made less low down hp in this tune then your original tune on page 1 :blink:
Edited by Butters
Thanks for that.
Full-Race have been using divided T4 1.06 ex a/r on their GT35 setups. See below link of this setup on a Subaru EJ25 (2.5 litre). Granted there not the same engines as a RB - but they both have similar capacity.
http://www.iwsti.com/forums/engine-power-p...out-5-24-a.html
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
