hey all
about a week ago my original water pump started leaking from the drainer hole thingy.
so i went off to the wreckers and bought a new one.
after the fkn hassel of taking off timing belt, harmonic balancer (took agesss to find the right HB puley remover) and all other other crap i finally changed the water pump...
put my new alim rad in, flushed the engine for 20 mins and all the rest of it, topped the coolant then SAME THING STARTED leaking!!
again, from the drainer hole.
my question is, was it just realllly bad luck to get a dogey water pump or is there something wrong?
if it is a dogey water pump, im definately going to buy a brand new one (if i knew it was going to be that much of a headache taking all that crap off i would have done it in the first place).
any help would be much appreciated!
thanks in advance
https://www.sau.com.au/forums/topic/220291-second-water-pump-failier/
yeah sorry it was a second hand pump. its leaking from the drainer hole from the bottom of the pump (exact same place the old one was leaking from)
keep in mind it started leaking the day i installed it, didnt even get to drive the car :)
should i invest an extra $30 in a n1 pump, or will the 50mm aluminum rad be enough to keep the temps down?
ohh true abu, i should just weld a 0.5mm tin sheet over where the pump should go yeah?
oh also i got aria forgies for my 13bt
ah you wouldn't be in all this mess if you had a 20 like a true r32 owner
arias forgies suck, I went all out CP forgies with spool rods, extensive head work and solid lifters in my old 13BT
you should invest in some procrams and cams gears for that rotor! really get that thing revving! :D
Unless you have a problem with them, I work at repco, I put a brand new GMB water pump for a RB30 on my 26 and its fine. Handles anything I can throw at it. I run stock rad, 16 PSI and it runs cooler then the stock pump did.
It cost me very little. What it costs the public I dont know, shouldnt be too much. If it was over 150 bucks id be very surprised.
question, if a mechanic works on ur car after they have been supplied with a part from a wrecker, and that part is faulty and the mechanic charges me extra for fitting/removing/fitting a new part, can i forward that invoice to the wrecker?
    • Nah, apparently the way to do it is just mess with how much timing the engine uses to try to correct idle. So it massively undershoots, then overshoots, then undershoots, then overshoots. So timing is going from 5deg to 45deg to 5 deg to 45deg. But I kinda prefer the car to not lurch around and have a dependable idle. Given it didn't idle for shit and stalled about 7 times on the way home, still yet to drive it for the 2nd time to see if it's fixed.
    • Best chop idle FTW, just add an idle timing hole lol
    • Alright. Many little things have been sorted and the car successfully drove home with an incredibly huge exhaust leak. Unsure if it's simply been awhile, but new heads and cam and intake sound f**kin awesome. It might only be me that notices it though, and it's hard to tell from a 15 minute gauntlet run home and attempting to bleed the radiator. Undertrays on, tools out, road brake pads in, idle un-f***ed, time to do some road tuning. From my commute around town it sounds and drives *really* nice (with a max of like 35% throttle). It'll go to a dyno for a proper before and after once the tune is more roughly dialled in. And @Dose Pipe Sutututu I did learn how to do a proper chop tune at idle. I did indeed even do it, but the car shaking around at idle from the driverr seat made me make it smooth again.. I feared for my engine mounts and clerances to engine bay jank. . After the exhaust is fixed I may mess around with it more. I'm just happy to have it drive around without bucking or stalling which is a WIP.
    • Oh and my rear arms may need some attention too.
    • Bushings are almost done. Check the date stamp 😂 these are likely the original bushings with 27 years and 243ks on them.     Was too dark to get a pic of the worst one.
